HTC Vivid wont power on (Just get Hboot screen)
Further to immediately above, I found a phone with fully charged battery and put it in mine. As an aside, I put my battery in that phone and it seems to be charging OK - light comes on and stays on. So I'm guessing that there's a problem in the charging circuit or software on the phone and I've wasted my money on a new battery.
Relocked bootloader OK.
Unlocked it again OK.
Flashed recovery as per instructions on other post. Again, I get the OKAY and finished messages in the command prompt and also the green bar going to the top on the phone. But when I disconnect the phone and then select recovery, I get the white screen with HTC Logo and no progression after at least 5 minutes.
Damn. Maybe a bad cord not sending all the packets together?
Sent from my HTC Vivid BoRKed using Android Central Forums
Tried multiple cords. Also tried it on a different computer... doesn't work at all on USB 3 but USB 2 ports give me fastboot USB and I can apply the fix... but no luck. Now ready to give up and maybe take it to a repairer.
This is...pretty excessive. I've never had a Vivid/Velocity act that bad before.
good afternoon all, im new to android, i have my vivid from htc unlocked running ics but the atnt bloatware on it is driving me mad, if i do a factory reset using the hboot screen will it reload to stock htc ics or atnt branded ics with all the bloatware again?
can some one assist me i have NOT rooted but i am running ics with atnt bloatware galore if i run factory reset will i get htc factory ics or atnt ics?
Actually, you'll just go back to out-of-the-box. You need to either root and/or ROM to remove bloatware.
Need ! Help ! my HTC Vivid HTC boot screen! Not enter in mode recovery only in bootloader .
S-ON
Unlock
4.0.3
recovery ClockworkMod
and Root
Please hELp
can you help me its urgent i flashed cm11albinoman2013 on my vivid now if i put in my sim, phone freezes for hours, and the internal sd card is unrecognized, i need another dwload another rom but the goomanager is crashing when i hit the download screen and i can get anywhere on cm's website to help with my vivid, reason for trying cm11 was my vivid went white screen this morning and refused to start back even after using recovery, can you please help me
U can Google a newer version of cm11 I believe i typed in cm11-2014015-Albinoman-holiday.zip n download the goapp for 4.4 also
Have all the HTC drivers installed, so able to get the phone connected to PC and able to see the red-background FASTBOOT USB as well. Tried running the RUU (htc_vivid_att_RUU_3.26.502.56_R23_US) couple of times now with different cords, no luck yet. It's a never ending 10minutes, phone even ran out of battery once and turned itself off after couple of hours. I would really like to see if there's a way to get the phone back up and running with some of the data retrieved, at least the ones on the phone internal storage, as I was not using an external storage.
Rebooting to bootloader........
Updating the ROM image on your Android phone...
This is what I keep seeing throughout the process on the PC screen, nothing shows up on the phone screen.
**** LOCKED ****
HOLIDAY PVT SHIP S-ON RL
HBOOT-1.85.0025
MICROP-0360
OpenADSP-v02.6.0.2226.00.0202
eMMC-boot
Mar 1 2012,17:09:49
Is there any way I might be able to retrieve the data on the phone? Would appreciate your help.
gruptysh
