Huge Problems After 4.4.3 AT&T Update
such an awesome phone hard to believe they would screw up an update as bad as it sounds...working so good I could careless if there was an update so I never look glad I didn't...sorry to hear all your guys/gals problems good job on being the guinee pigs though..im sure there will be a fix
yeah I couldn't leave a good thing alone either.
so I turned off fast reboot and restarted, the phone seems to have cooled down some, I'll see how the day goes. I also just did a system cache wipe so I'll see if that helps anything either...
Side note - not sure if I just didn't notice this before, but, now when I'm on wifi the 4G symbol shows the 4G connection basically constantly active (with the moving bands back and forth), is this normal or should the 4G be pretty quiet when on wifi?
ouch. bad updates have happened before. the real PITA is waiting for a fix ...
did the same thing last night. fast boot off seems to cool down the phone.
did a cache clear thru hboot and the batt life is still draining fast.
not sure about the 4G icon.
Just reported to AT&T, she said she hasn't heard the issues personally but that it does seem to be trending...
System cache clear didn't solve battery issue, I'm down to 77% in an hour and a half with basically no usage, just rebooting a couple of times...
Say what you want about vzw's delay in rolling out updates but if it's because they test/QC the heck out of an update before rolling out, I'll take a delay any day.
Sent from my HTC6525LVW using Tapatalk
Add another one to the list of people having problems.. WTF AT&T? Bad enough that we had to wait so long for this software update, the least they could have done was make sure it was working first.. Totally frustrated..
this thing wont be pushed automatic I hope do they still do that? had my other phone rooted for 3 years never worried about it..hate having to do something I don't want when it works just great
I'm certainly not a pro, but I do not think they can auto-update it.. Avoid it like the plague if you can..
The New update has completely, jacked my phone, and when I called in the guy at At&t stated that there was something wrong with me because his M-8 was running fine... Then he hung up on me WTF... Does any one have any new info for a fix.
Wow, call back, they need to be barraged with people reporting this issue so that they can send a fix out...
shawnjosecrespo
