- Aug 16, 2010
- 3,151
- 0
- 0
Has anyone bought this one?
https://www.amazon.com/Hyperion-Ext...ag=hawk-future-20&ascsubtag=UUacUvbUpU5695923
there are reviews here or in the accessories threadHas anyone bought this one?
https://www.amazon.com/Hyperion-Ext...ag=hawk-future-20&ascsubtag=UUacUvbUpU5695925
Some users over at XDA as well.Thanks.. I keep forgetting about that thread.
http://forum.xda-developers.com/v20/accessories/hyperion-extended-battery-2x-battery-t3546698/page8
I was just about to say that.. they seem to like it a lot over there.. I'm considering it.
Also take a look at the Perfine version. Comes with two backs so you get both colors.
It doesn't have the praise that Hyperion does on Amazon. I'll see what I decide when I actually purchase one.
I think its the same unit.
If I'm not mistaken, there's not very many Li-ion cell manufactures, so it's likely many of these different brands are getting the same cells.Unless they were all manufactured in the same location (China) and has a different label on them.
I don't think so. There are a lot of random extended batteries for the V20 that looks the same... Unless they were all manufactured in the same location (China) and has a different label on them.
How was it doing the initial charges and how long did it take you to drain it?I've had the Perfine battery for over a month now and it performs just great. I'm very satisfied. I'm getting about 2 days of use per charge, with moderate to very heavy use (much of it on the TMO network; the rest on wifi). I can recommend it without question. The backs have a good feel, too.
It took almost two days to run the battery down to about 5%, before I recharged it the first couple of times. In fact, I used to do extra unnecessary things to try to run it down before recharging. When I first got it, I put it on charge immediately, even though it came with about 50% charge, and didn't use it until it was fully charged + a couple of hours. And I did this the first couple of charges. Since the "breakin period," I'm still getting two days of use.
