TTQ225
- Nov 2, 2015
- 131
- 0
- 0
How is the camera, compared to the s6?
Does the double click home button to open camera from any screen work like in the s6?
Can't answer #1. Double click opens the camera.
How can I get my Note 5 to allow me to search the internet while on a call?
ready to throw this in the bin!!!!
I use apps that use 3 dot menu key (overflow menu) that are not being upgraded
the long press method only brings up the split screen
come from am HTC M8 which still has the 3 dot menu key
also just checked an Nexus 5 which also has the key
do not buy a Samsung Galaxy Note 5
unless there is a solution
go for an M8 or a Nexus
the apps work on HTCC M8 and not on Samsung
that is a fault with the phone
Samsung changed away and obviously did not check or think about this problem
I repeat
I have a Samsung Note 5, running 5.1.1
Kindly assist me to clear the S Calendar entirely. Unnecessary accounts are visible under S Calendar, i don't just want to deselect them but delete / remove everything.
I have tried the following:
1. S Calendar, More, Manage accounts - i can't find an option te delete account
2. Settings, Applications, All, S Calendar, Clear data & clear Cache - it did not remove anything from the calendar
I used side sync and smart switch to swap from my Samsung S5 to the note 5. That is why some of the accounts and calendar entries are duplicated.
I just spend 30 minutes on the phone with the Samsung help desk and though the guy was very friendly he could not resolve my issue. He suggested i backup the device and master reset everything and restore but not the email accounts or calendar and set those up manually. That sounds to risky to me, surely the software should allow to remove the content.
It would be great so clear everything and start over completely. PLEASE HELP ME!
Anyone know if the ram management issue is going to be fixed? Having 5 apps opened at once isn't very impressive for 4GB ram. I am getting a 6P but I might go back to the Note 5 if the problems are solved.
I didn't know that there is a RAM management problem with TouchWiz and the Note 5. Is something in the Note 5's Android implementation preventing more than five apps from being open at a time?
Nothing wrong with 6P instead of Note 5, just wondering if there is a specific article or thread about the Note 5's apparent RAM management problem. I'd like to learn more.
Apparently with the Note 5, you can't open more than 5 apps at once, otherwise it'll close them. That's the same as many other phones, but the Note 5 has 4gbs of ram while others only 3.
Well that's just flat out wrong.
Not what I had in mind when I said running 5 apps at once... But ok, sure. Have you tried running 6 games at once? That seems to do it for the NOte 5 as it has to reload.
How else would you run 5 apps at once?
Why would I ever be playing 6 games at once?
First it was 5 now it's 6. I don't know. I had 6 windows open simultaneously and jumped from one to the other with no problem.
Well I DID say "more" than 5 apps at once. Why? I don't know, if you have a lot of games and you end up checking all of them, but forgot something on the 1st game you played, and have to go back and do something. Realistically, it would probably be like 3 games and a couple other apps running at once, easy.
Further to this missing 3 dot menu bar
there is a partial solution to at least one of the apps in question
found by trolling around the other forums
settings, personal, accessibility, dexterity and interaction, assistant menu, turn it on
then in the program press the 4 squares and scroll down or up to the menu
the other apps still do not work when pressing this substitution for the 3 dot type of menu bar
still not impressed in Samsung's removal of the 3 dot menu
will still not recommend buying a Samsung to anyone
