I have a Nexus 4, you have questions. Fire away.
Is there settings to enable Wi-Fi hotspot with the Nexus 4?
When Google released 2.3 for my NexusOne they added this feature in Settings.
Hi I'm new here and I have a question,
If I get the Nexus 4 from T-Mobile will I get the OTA updates at the same time as those who bought it from the Play Store or will T-Mobile delay the updates?
You should be getting the updates at the same time because tmobile won't be tinkering with it. It should be the same exact hardware and software.
Sent from my SGH-T989 using Tapatalk 2
Any experience with VOIP calling on device? Does the Nexus 4 have a built in SIP client? Why does T-Mobile say that there is no wireless calling on the Nexus 4 on their network?
They just don't include their proprietary wifi calling app on the nexus 4.you can use any voip app on the market to do wifi calling
Android also supports SIP out of the box.
Phil, not sure if you have anything regarding this, but in your "Unlocking the Bootloader" video the menu says "Secure Boot enabled" do you know if it has anything to do with the secure boot stuff for Windows Phone 8/Windows RT?
I did a search and I can't find and answer...
Is Slimport compatible with MHL? OR is it a completely different standard?
Will Slimport allow connecting to any standard HDMI port (without charging)?
Thanks again for the help....
Is it better than the Razr Droid HD? I'm from Brazil and LTE will be deployed here in 2013/2014. I'm traveling to the US next month, so I want to buy a new smartphone. Which one do you think is better? Non-LTE, amazing specs and low price LG Nexus 4, or the Razr Droid HD (which supports the 4G frequencies that will be offered here in Brazil) ?
Uhm, so if i buy the device straight from Google Play Store, if there is an issue with the device, do I get any kinda warranty for the device? also if I put my Tmobile SIM in it, will I still get OTA update from Google or it has to go through Tmobile?
So, the version bought from T-Mobile is exactly same as the one from Google Play Store? Both unlocked, both stock, no splash screens, no bloatware, etc...?
Phil how much actual screen estate do we get? I know its 4.7 inch screen but the on screen buttons take up space
Actual screen is 4.45" for everything but videos, where the screen keys disappear and give you a 4.6" diagonal as the phone is not 16:9.
donbradman56789
