I have the Honor 8 - you have questions - ask away!
Sorry if this question has been asked but how do I make contact groups on the phone? It only has a favorites option. Thanks
Hi All
i already using my honor 8 for 3 weeks, at 1st all was okay. but this lately i got problem with connection from sim 2, when i make phone call using sim 2, other people cannot hear my voice, its like bad connection but i hear they voice loud and very clear. Pls advise if u got the same problem? what should i do? is this like some factory failure product.
Hi All
Have you tried to restart the phone?
Hi All
Also check out if the sim card is placed in correctly to be read. Have you tried switching the sims around to see if it is your other sim, or the slot itself?
We are sorry to hear that you're having problems with your Honor 8. We advise that if the listed troubleshooting options are not working for you that you give the Honor Support Team (1-844-524-6667) a call so that we can help you fix this issue. (RL)
I already doing that, try to switch it and the problem still the same, i also try using a diffrent provider thought its was the provider connection problem, but same, not working... can someone advise how to check our guarantee by online using some application, coz when i buy this, the seller show me a huawei application who can directly check our guarantee period by input our IMEI number. Now i began to think that my devide is not original or some factory failure product
Robputra, I'm sorry to hear that you're still have trouble with your Honor 8. Have you tried contacting the Honor Support Team? Upon receiving some more information from you, they can walk you through more extensive troubleshooting steps. The phone number is 1-844-524-6667. (RL)
@robputra - I'm sure our friends at Honor will be able to get your problems fixed up! Let us know how it goes after you give them a call!
So does auto brightness not work on this phone? Auto seems to always move that slider on to the dimmest setting. I have auto checked off.
It works much better now. Make sure you have the latest update installed.
Does the screen get bright enough?
It seemed a little dim with auto brightness turned off although I was comparing it to a super amoled screen on the Moto Z.
-Rich
-Rich
Since the update, I have had no issues with brightness and I only use auto brightness.
websitedesig101
