I need help rooting my Droid Razr
braxster1992
Ok so I have been trying to do this for the past day. I have a droid razor xt912 and I am trying to root it. I am doing it on a mac and this is what I get.
* One-Click Root Script for Droid Razr
* brought to you by DroidRazrRoot.com
* Credit goes to XDA user djrbliss Dan Rosenburg for exploit.
This script will give you
1. Root and SuperUser
2. Install Busybox
Before you begin:
Please read full tutorial at DroidRazrRoot.com!
waiting... If you get stuck here, try another USB port.
Start Rooting...
reboot #1 - DO NOT DISCONNECT YOUR DEVICE!
rm failed for /data/local.prop, No such file or directory
/system/bin/sh: can't create /data/local.prop: Permission denied
reboot #2 - DO NOT DISCONNECT YOUR DEVICE!
remount failed: Operation not permitted
failed to copy 'su' to '/system/bin/su': Read-only file system
Unable to chown /system/bin/su: No such file or directory
Unable to chmod /system/bin/su: No such file or directory
rm failed for /system/xbin/su, No such file or directory
link failed Read-only file system
failed to copy 'Superuser.apk' to '/system/app/./Superuser.apk': Read-only file system
rm failed for /data/local/tmp, Permission denied
failed on '/data/local/tmp.bak' - No such file or directory
3889 KB/s (1075144 bytes in 0.269s)
mount: permission denied (are you root?)
/system/xbin/busybox: cannot open for write: Read-only file system
Unable to chown /system/xbin/busybox: No such file or directory
Unable to chmod /system/xbin/busybox: No such file or directory
/system/bin/sh: /system/xbin/busybox: not found
rebooting
All Done rooting Droid Razr, subscribe to DroidRazrRoot.com for more cool stuff like ROMs, hacks, tips, and more!
RootMac.sh: line 52: @pause: command not found
After that I go and check my phone to see if it worked and it didn't. I need help badly as to I am new to android and rooting.
smith-jhone
