I spilled milk on my Nexus 7 and need help.
kal1209
56
I accidentally spilled some milk on my Nexus 7. Some of it went into the headphone jack and started making clicking sounds like I was typing. After tapping the top of the device on my bed to get the milk out it seems perfectly normal. Is it this durable or did I just get lucky? I have geek squad accidental protection with it but I don't see a reason to bring it to them since it works fine. Thank you.
Keep an eye on it over the next few days. I think you made a major withdraw from the Luck Bank.
What should I look for? I can't believe I was this lucky. Even when I shake it it doesn't sound like there's any liquid in there.
Just the device acting weird. Mostly if the screen acts up or the headphones.
I wouldnt be too sure on luck as you will have to monitor it as my friend did this then 7 days later her phone fried so she had to get a replacement just keep an eye on it like other people have said:)
Sent from my GT-I8190 using AC Forums mobile app
It'll likely be OK, but if your N7 acts up, no use crying over spilled milk. :-D
That's gonna smell great in a few days :D
If it's working then don't sweat it!
Sent from my Nexus 7 using AC Forums mobile app
No use crying over spilled milk.
Seriously you might want to spray some contact cleaner into the jack but aside from that I don't think you have to worry, if it's working then you are OK. Milk isn't corrosive so I don't think it will do any long term damage.
I tested it with headphones and they worked perfectly.
It's been 3 days and I cannot find any obvious problems with my Nexus 7.
