i take it back battery is trash!!!!
This is why with my g4 on its way will be at my house monday I am worried about the phone. Battery life is key for me.
Sent from my SM-N910V using Tapatalk
I think there is something wrong with lollipop. I got much better battery life on my note 4 prior to lollipop.
Same here.
Sent from my LG-H811 using Tapatalk
Its not bad at all but not great by any means. Through 4 charge cycles I'm averaging right at 4 hours SOT which is pretty much the same as my S6. BUT the G4 does give you the option to pop in a spare battery so there is that.
Aggie I appreciate the insight. I guess my hope is a software update fixes this issue. My note 4 is killer at battery life. I like to have another phone to swap to as I get bored and intrigued by new tech, just carrying another battery I guess is a first world problem I shouldn't complain about, but hope I won't have to
My Note 4 had amazing battery life prior to upgrading to Lollipop. It seems the G4 and S6 so-so battery life is all attributable to Lollipop. I'm sure, as you said, with future updates it can improve.
I believe the wakelocks are the culprit.
Google Play Services, Facebook and Facebook Messenger are often the biggest culprits.
My G4 is coming soon, and I'll be ordering an extra battery kit and a Quick Charge 2.0 wallwart (sadly, I don't live in the States ATM, so I'm missing out on the battery freebie.)
Android M should sort out the battery issue, especially on standby.
I haven't researched but is there an eta for M? I'm guessing a long ways away since lollipop just dropped.
I've been reading a lot about the nexus 6... it's an intriguing device to me especially now that my g4 is enough route with "poor battery life"
At I/O they announced end of year for Lollipop to start or 4th quarter.
It really is true that what you're doing with your phone affects the SOT. I've noticed OEM's have gotten pretty good at optimizing SOT when streaming video, such as Netflix. But use your phone for anything else and it's not as good.
That being said, the battery life on the G4 has been a bit of a letdown.
Battery life in any phone is good for some and bad for some. Sometimes it's a bad unit and sometimes it's a bad battery. Sometimes it's just bad.
It's always best practice for the user to factory reset or exchange the unit. If it's still bad for your use, then there's nothing wrong with moving on to another device which hopefully performs better.
I'm lucky enough that the battery life on my G4 is awesome for my use. Couldn't be happier.
Posted via LG H815
Posted via LG H815
^^this^^ x1000 ...on point!
Battery life has been excellent for my use! As a matter of fact, I haven't been able to get it below 30%. I must be a weak user, lol!
Start gaming on it, lose that 30% like a power user! lol
I would but for some damn strange reason I start passing out when I play games or watch anything on my commute. I've dropped my device many times this way.....no bueno....lol!!
So, I think I found a good fix for the battery. Last night I unsynced a lot of Google stuff. Today I've had it off the charger for about 4 hours, I have only 30 mins of screen time, but the battery is only at 96%!
Well yeah, things like this may not always be obvious.
Any work your phone is doing (like syncing all the time, trying to find a good signal, etc) is going to eat into the battery life thru shorting SoT. Even using LTE as opposed to 3G will shorten battery life between charges. The LTE radio is much more power hungry than 3G.
SoT measurement, for comparison is almost a useless thing to compare.
Way too many variables.
Where did you go to change those? Thanks.
Uhhh.. You are playing games and watching videos when driving? No wonder you are passing out! Hitting those telephone poles would cause me to pass out too!!! 😆😆😆
My battery life has just been so-so as well. I have the H815 and I'm using it on T-Mobile. It has been slowly getting better the more I use it though, so I'm still breaking the battery in. I have it on auto brightness but I also changed the slider from 100% to 50% and it improved the battery.
I think part of my problem is that I'm coming an Xperia Z3 which gets phenomenal battery life. I thought the Z3 was the same as other flagships but now I'm realizing it really is better.
If you're on T-Mobile try to disable their diagnosis features and their WiFi scanning tools. That helped my battery life a bit. At first I felt the same as the OP but 5 days in it seems like it's getting a bit better. Yesterday I finally got a lil closer to 4 hours of screen on time. Hopefully it Will get better.
That is one of the problems, battery usage is very subjective and a lot goes into it.
Very true. No one talks about cellular signal strength or quality. I live in a fringe signal area and my Note Edge can hold on to signal and battery is phenomenal. S6e didn't stand a chance. G4 is better at signal strength...thus better battery life at home. In downtown, it is superior.
I recommend others to measure batt life in airplane mode to see the difference cellular makes.
Sent from VZW LG G4
Sonfollower28
