I unlocked..Want to flash 4.0.4
now turn off your phone, and turn it back on by holding ALL THREE together: Vol up, Vol down, and power - keep them pressed until you get to fastboot mode
phone should say start with android on his back btw
actually wait a sec forgot we didnt root it.
my bad
we have to take a step backwards for a sec.
on the phone, use the volume key to either restart the phone or power off
we need to put the rom (stock 4.04) onto the device before we do recovery
You're going to place that file in the Download folder of your SD card, leave it compressed as it is (don't unzip)
after you have moved it over to your sd card, turn off the phone and restart to the bootloader again - vol up and vol down and power together
while your phone is connected to the cpu via usb - you get the mtp protocol don't you? wehre you can see the files on the "sd card" of the phone?
Android file transfer for mac
You open up android file transfer, and you drag the file to the File Transfer Window (what is in that window is the "sd card" of your phone).
Drag it to any folder it really doesnt matter, i just use the download folder bc it's easiest to remember for me.
jafar
