- Jul 18, 2010
- 131
- 18
- 0
Okay ill use the download folder once the file stops downloading its almost done
(College Internet blows)
on the phone in recovery mode - go to backup and restore - backup - make a new backup
this will take a while, but it's a safety measure so you should just do it because otherwise if there is a snag the fix will take too long. and it's late. and my gf wants to go to bed. and i do what she says most of the time.
..... now we wait for it to make your backup.
when that is done, still in recovery mode, go to Wipe Data/Factory reset. Select yes when it asks you to do it.
After that, select Erase Cache - select yes.
After that, select Advanced then select Clear Dalvik Cache - and select yes.
After that, select go back to get back to the main menu.
In the main menu, select Install zip from sd card.
Then select Choose zip from sd card.
Then, select the Download folder, and then select the 4.04 rom you moved over there.
That will install for a minute, and then you select Reboot system now.
