ICS available through manual pull on June 30
I'm just hoping they fixed a few of the bugs, anyone care to post a screen shot of the build once installed?
Sent from my DROID RAZR using Tapatalk 2
Didn't get the push, but the manual update worked. In Toledo. Now to check out the changes.
edison
Got the manual pull. So far so good .
Post upgrade brightness defaults to dim.
Sent from my DROID RAZR using Android Central Forums
I don't care what kind of phone you use, that's not how I judge someone's worth or intelligence. Sent using tapatalk 2.
Reactions: bradenfontaine
I installed ICS yesterday. It's great, but now Samsung Desk Home & Car Home no longer work. What's up with that, AT&T??
This is the same build that was released to the soak testers.....me included....if there are any bugs in the build, they would not have changed the release, they will be incorporated into a bug fix for release later.
If they had needed to change the build, the roll out would have been delayed pending a new soak test. Which makes sense. Anytime you made a change in code, the possibility exists of unexpected problems.
The soak showed the build was good to go for most users, so they released it. It was interesting, because of the posts of people unable to do the update, it was 50/50 rooted vs. unrooted.
Reactions: Ry
Discovered first annoyance with ICS. to snooze or shut of alarm can just touch screen to snooze. You have to pull down the curtain tap the alarm then choose to snooze or turn off.
manual update.. ICS!!!!!
Looks awesome.. but man.. is my razr maxx extremely slow now..
hopefully its not a consistent thing
iasolutions02
