(ICS)CM9, Now 3g!
Re: CM9 For the V, Wifi works.
@ asadullah the ril files are they like this
ro.ril.hsxpa=2
ro.ril.gprsclass=12
ro.ril.hsdpa.category=28
ro.ril.hsupa.catergory=9
This is off the Atrix 2, but thought that might help some where.
Looks familiar I'm knee deep in some evo stuff right now but what I would do if your slightly patient and have the know how what I would do to get an actual map to get this running. Is to take the stock sprint rom and dwonload the update remove the radio and recovery and apply it then update again each time removing the radio and recoverys (also dat files if any). Till you get to the gingerbread update.
Nandroid backup that sh!t so that you got a system and boot image to use for unyaffs then go from there and change out the ril files mess around in system/lib and system bin also if you change things they need permissions added to a file can't remember off hand where it's at but it gives permission to telephony hardware.cdma when you try the gsm version thats what you wanna mess with.
At least that's how I did it when I ported the mytouch rom to the sprint hero back awhile ago .
I think to get the radio working you gotta switch the ril files something in the ramdisk and maybe something in the buildprop and worst come to worse something in eri.xml don't remember 100% been awhile since I messed with anything. Theres also another driver or something it's nothing too complicated. It's just trial error and reboot.
I tried changing the ril class in the build prop, but nothing :/
Sent from my Amazon Kindle Fire using Tapatalk
Holy moly, and I thought my computer got bad when theming!
On another note: This seems to be the fastest development I've ever seen! Day 1, I see cm9 barely boots on the v. Day 2, I see we have a cut down ROM and devs taking interest. Day 3, I refresh the page and suddenly we have hw acceleration! Crazy stuff. You guys are doing great work.
Tapatalkin it from my IHO CM7.2'd, MIUI Themed Optimus V
I wish I could do more to help most of them, but I never got the time to learn how to build. I have a PC that I tinker with, maybe I can reformat everything and use it for building. I'm more of a themer, not a builder.
Sorry guys, Keep up the good work! :)
In all honesty, I'm not even building anymore. Me and me2151 are just tinkering with the zip, and porting over all the libs that lupohirp makes.
I need for you guys to do something for me: find a way to test for hw acceleration. We think we have it, but have no sure way to test... It's very important to find this...
Maybe try a benchmark where you know it's not working and another where you think it is. Obviously try to change nothing else. Then again I'm not a Dev and may be way off on this. But that's the best thing I can think of
Sent from next year on my CM 10ed G-Mobile Galaxy Note 2
Ill test, although my sd card slot is broke, I flash a new rom everyday still....
Hmm.. well it seems we didn't in fact get hw acceleration working :/
But, were working on it and we did accidentally make it faster ;)
I saw Drew say something about the Kernels?
Speking of which, this kernel is amazing. Any chance of porting it to the Optimus V?
Sent from my LG-VM670 running IHO MiRaGe using Tapatalk
Gingerkernel? If so, it works on the V for CM7. I think something stops working, but its pretty damn well. Keep in mind Bob's kernels are.specific for the CM7 build features.
Re: (YOUR RISK)CM9 Optimus S boots on the V
Success.
I've got CM9 ICS running on my OV. It's able to place phone calls, send and receive SMS, and pair with bluetooth devices.
I'm going to tidy up a bit and create a drop soon.
I think you just met your deadline. ;)
Here it is: tdm-cm9-vm670-alpha1.zip
This is an alpha release! Many things are broken! Install it at your own risk!
Working:
  • Phone
  • SMS
  • 3G
  • Bluetooth
Not working:
  • Button mappings are wonky
  • Camera
  • Clock widget
  • Probably lots more
Huge thanks to the following folks, who made this possible:
lupohirp for the initial port to the P500
drewwalton19216801 for the port to the Optimus S
blarf for creating IHO
LeslieAnn for the awesome build server
Once a few folks smoke test it, I'll create a new thread.
Not working:
Import the generic.kl file from my ROM posted in the OP. I've fixed this :)
Jsyk, it goes in /system/usr/keylayouts
Reactions: tdm
dooleysdickulove
