Ics launcher
Yes
Once you root with gingerbreak
Install the flash image gui and you can install a custom recovery with that
Then boot into recovery and make a backup
Then reboot download a rom youd like and the gapps
Reboot back in recovery, perform wipe and then flash rom and gapps
Reboot 2x and enjoy
All the links should be in the post linked above
Cm7 is just a base for gingerbread roms
Cm9 is ics
There are a ton of cm7 roms located in the rom section of the forum
noroldie
