Ics live on verizon
Big visual difference. Might be a little bit slower. You can keep scrolling through the home screens now.
Decided to go for it. I'm on wifi but it insists on using 3g. Ugh.
Sent from my HTC Thunderbolt
Holding down the home button to see your most recently used apps looks a lot cooler now. It shows you what was on the screen when you closed out of each app.
The note 2 rocks! However I think it might be too big I hadn't decided yet. I really would like to see what impact the update has.
Sent from my SCH-I605 using Tapatalk 2
Can you still get S-OFF or root with the available tools after ICS is installed?
Since the OTA package includes an updated hboot, so I was curious if anyone who installed the OTA update, if they were now limited, or stuck?
Just playing around with it; some times it's a small bit slower, some times it's actually a bit faster. The only problems I've had with it so far is my notes widget is extremely wonky and won't work right, and long pressing a couple widgets has been kinda iffy. Haven't done a reset yet
I let a lot of the apps update, then did a complete reboot, runs MUCH better
Seriously? I think the Note 2 is just a little (just a tad) more up to date than the T-Bolt...
HAHA!! I thought i could bring out some of these comments! Actually, I'm still on the fence with the Note, its a bit difficult for me to use one handed, which truly could be a bit safer since I spend a lot of time on the road. It is super fast and I am starting to figure out some uses for the S pen. I really want to upgrade my Tbolt though, my wife is still using hers, if I take the SIM our of her bolt and put it in mine, will it update without causing any issues?
I'm having problems opening text messages. It seems like if I have only a few from a person it will open up but for people I text a lot, it just keeps saying "Loading.."
I have downloaded and installed it and I have to say that I'm quite happy with the update. The phone works smoothly and I love the changes to the lockscreen, etc.
It seems to take a while to update all of the older stuff. Mine seemed to take at least 10 minutes just to load old conversations. My photos were similar -I thought I lost them for a while, until they were updated/loaded.
Try opening the message app and give it a while to load old messages.
What sorts of testing are you looking for? I may be able to help you out if you can walk me through it.
So far everything seems great.
I'm rooted on a custom Rom, but I am so tempted to restore to my stock nandroid and download this, even though it would mean losing root.
Sent from my Sense 4 ICS Thunderbolt with Tapatalk 2
OK, downloaded it - took a few tries since my data connection kept dropping (maybe this is fixed with the new radios? please?).
So far so good. I run MobileIron and Touchdown, and both seem quite happy with the transition. ADW Launcher works fine, so I can't really comment too much on Sense. Swype Beta seems to run fine. Disabled all the bloat I could find and nothing is blowing up yet.
I'll report more in detail later, but I haven't found anything that does not work.
HuanNguyen
