Ics live on verizon
I'm on stock 2.3 and rooted, update keeps failing to install, keep getting the big exclamation mark before it takes me to CWM screen where it says something about bad signature. Seem to recall same issue when updating from 2.2 to 2.3 way back when. I can't remember the workaround, maybe unrooting required I think. Anyone else having this issue?
If someone has the OTA zip please post it, im going to try to find temp root and work with rev to possibly get s-off
ok, done. Took about 30 minutes to download and install. Been playing with it for about 30 minutes and can't see any problems so far.
Reboot is a lot faster, and woah nellie I CAN TAKE PICTURES WHEN THE PHONE IS LOCKED! That's huge great news!
Oh, and critical function - Ingress works fine. I can continue resisting.
Sent from my HTC Thunderbolt
There is an issue on my wifes TB that when she clicks on someone to text it will put random words in the text box without her typing anything at all.
That might be your problem. They aren't supposed to be blank... You should have by default. Phone/camera/messages/mail.
Try restarting?
Sent from my ADR6400L using Tapatalk 2
Since people seemed to not be having problems I downloaded the update about 20 minutes ago. So far I'm seeing solid 4g again (26 down 10 up) for the first time in at least half a year. Amazing. My Thunderbolt has become fully operational again.
I haven't done speed testing on 4g but on 3g I'm getting almost 1 meg down, 300 kb up, which is at least double my previous average.
Are you kidding? I've had the thunderbolt a couple of phones ago and now I have the Note II. Believe me this thing is a beast and the thunderbolt is a joke in comparison. By the way my wife still has my thunderbolt. The amount of difference in speed is like going back to 3G.
Try restarting?
Ah, well two restarts and the other 3 are still blank. oh well everything else is working fine so far.
Does anyone know if you will be able to upgrade over wifi only? I am not activated, ordered a Note 2 and want to decide if it would be worth it to send the Note 2 back and continue using the Tbolt now that we finally have ICS.
Well, I mean, the Note II is a little bit newer than the Thunderbolt. /double entendre
Even phones the generation after the Thunderbolt would look like a joke.
MWavy06
