[INDEX] EI22 Gingerbread ROMs/Themes/Kernels & Mods List
Have been using Legendary Rom with latest zip update and love it except...each time I leave wifi at work or home, phone can't find a mobile network either 3g or 4g. I won't get email and can't use browser. I have to go into settings and uncheck 3g, or reboot. Yes, I have good coverage where I am. Any ideas? Could this be a kernal thing?
And if i wanted to install a different kernal or the updated samurai one, all I would do is put on sd card, boot into recovery, and unzip it?
Reactions: mpoehling
If you want to update the kernel just download, boot into cwm, wipe dalvik cache, cache, and install from sd card like you would a rom. Hope this helps! :-P
Sent from my SPH-D700 using Tapatalk
Could someone tell me how to get the ICS Theme 2.0 to work?
Or rather- does the theme include the ICS looking launcher?
Using ACS ICS 5.5 atm, and I swear all three of those links in the OP only change the lockscreen.
I installed Legendary and about 2 days later, I am unable to get a 4g connection. 3g works fine but 4g won't work in areas where I know 4g would normally work. Is anyone else having this problem???
What verssion of legendary are you using? I get a fine 4g connection with rc1 rc2 rc2.1 and haven't ran 2.2 yet but there has been no mention of 4g not connection on the legendary thread on xda
Well, I've changed to SleeperROM. And the same thing has happened. After about 2 weeks, no more 4g connection. I don't get it. It couldn't be coincidence that it's happened around the same time after installing for both these roms. I'm relatively new to using custom ROMs but would it be something to do with the modems that they're using.
Unrelated issue is that recently I keep getting FCs on my Google Services Framework process. And whenever I use wifi tether, after a while my phone reboots itself.
Thank You this is such a big help, now if it could be done on with Randomking's 3.3. I am looking for fat free and rooted, but was also looking for more go launcher apps in them, I like the go goodies. If you know of any please let me know.
Thanks again...Very Helpful
:D
Can someone make a designated thread for cm7? There's a ton of info spread around different threads and I'm quite confused. It would be helpful to have it in one place!
We do have one, unfortunately it has already been buried in the list..
[ROM] CyanogenMod 7.2.0 RC0 for Samsung Epic 4G SPH-D700 - Now wi
I'll run through and give it an update on the OP for features/version.
TheGreatApe00
