installed enhancedgooglesearch.apk on sc 2.9 need help
m1911a1
19
I was anxious to debing my phone and installed the enhancedgooglesearch.apk on the sd card. Now the phone is slow and I get a repeated force close com.google.process.gapps has stopped please try again. I have since found the thread that says not to install on eb01. Doh!
I have tried to delete any file that is related but it keeps coming back. What are my options to fix this? and can I get google on the search button on sc 2.9?
Flash superclean 2.9.2
Will 2.9.2 allow me to install enhancedgooglesearch.apk? and get bing completely off my phone?
I just flashed 2.9.2 and the force close problem got worse. I could barely get the phone to power down. I am flashing again right now. Any suggestions?
Clear your Dalvik and cache partition before you reflash.
I am really over my head here. This is my first time in cwm. I cleared the dalvik and cache partition. I am flashing once again. Is there a way to exit cwm without booting the phone?
You can pull the battery and that will stop the boot process. I was under the presumption that you had Super Clean 2.9.2 on your sdcard and you were going to install the zip from there.
Are you going to reflash with Odin?
I cleared the cache and pulled the battery. Flashing now with odin.
The phone calmed down enough for me to get a copy on my sd card so I will go that route if this flash doesn't work.
I really appreciate the help.
Hopes are that you are able to get your phone wrangled. I have to step away... work calls.
I downloaded 2.9.2 This file- EC10SC292x_DXC.tar and then extracted it and used .md5 file in odin.
I just flashed after clearing both caches and pulling the battery in cwm. When I put the battery back in, the phone was still in cwm. I rebooted from there and still have a force close loop.
What build and baseband were you at before. You said you read somewhere not to use the enhancedgooglesearch.apk on EB01. How did you get to EB01? The FC issue seems like you were actually coming to 2.9.2 from and Eclair build.
why would you not want to boot the phone.. it is after all a mini pc with a phone.
if it were me i'd use the soft menu key and reboot..
I went from bone stock to superclean 2.9. I had no issues at all. The phone was great. I installed that .apk file and It gave me my force close problem.
Punk
