Installed the Kitkat 4.4.2 rom.. WOW
If memory serves me correctly, CM ROMs don't give you the option to update PRL. You need to flash a stock ROM, update PRL, then flash back to CM.
OK. Since I assume my PRL for stock was already pretty current, perhaps the issue is something else.
I will start to gather info for the developers... although it seems like my problem is something that would impact a lot of users if it is what I suspect it is. :)
Are you able to flash different radios to your device? On my Note 2 I can flash different versions of the radios when an update comes out.
I am not really sure... I will have to look around to see. I haven't read about anyone doing it, but I haven't specifically looked.
Did you make sure you are using the correct recovery? You have to use specific recoverys for the 4.4 roms and I'm not sure if the others work for the 4.3 roms. I've seen a lot of talk about using the right version your recovery or your flash will fail.
I'm having an issue that I've been experiencing since I've installed the nightly builds. It'll work fine for a few days, and then suddenly parts of the data connection won't work unless I reboot.
What I mean by "parts of the data connection" is that The Playstore will load images, it'll show me my installed apps, but wont update any. Pinterest wont load any images. The web browser will work for viewing sites, but Feedly says no connection. Facebook works, etc..
If I reboot, it works fine for a few days and then this issue reappears.. anyone else seeing this?
That same things going on with mine but I'm running AOSP KitKat not cm which would lead me to believe its a kit kat issue itself
Sent from my LG-LS970 using AC Forums mobile app
I am having a good experience with CM11, using the latest 20140306 nightly.
The problem that persists is the use of headphones for calls. I can't hear any sound when trying to call/answer using them and if I take the phones out the phone's internal speaker doesn't work (it reverts to the "normal" behavior only with a reboot).
LG E975 / CM11 - nightly 20140306 / radio firmware europe open 10I
Can u send me complete details how to root & install a new custom flash rom on lg e970
Or the link for the page in including the download files for andriod 4.4.2. Kitkat
Thank you.
Riothetruth
