Instant Battery Fix for all complaining Epic Owners!
I ordered the batteries and got them before I had the Epic. I've been rotating the standard battery and one of the china batteries since day one with no problems. I've been using this pholne a lot and the two batteries have been working for me. I haven't tested the batteries but they seem about the same. I bought the black sprint case and it is a pain to pry off the back cover to swap the batteries so a lot of times I don't use the case.
Not that I don't appreciate your suggestion, but I would find this product to be a highly suspect product for $10.
I would also be concerned about whether these statements are factual:
  • This replacement battery has an integrated microchip that prevents overcharging and lengthens battery life.
  • Best replacement for the original battery with comparable standby and talk time.
  • Capacity :1500mAh
  • Battery rapid charge
  • Safety cut out circuit
  • Built-in protection circuit prevents overcharging.
Also, if the AC output is: DC 4.2 +/- 0.05V , 350mA +/-50mA there is nothing rapid about that.
When you put out the kind of money you do on this phone, I would highly recommend OEM batteries and chargers if at all possible.
Got them they work great. These batteries even have the indent for a water damage sensor on them so they might even be made by the OEM supplier.
If I have to carry two batteries in order to make it thru one work day I will simply return the phone and leave Sprint. Hopefully there is a fix before my 30 day trial is up because I absolutely love this phone.
careerzoneacademy
