Is it bricked, or can it be fixed?? Help ASAP please!!
I dont have adb or fast boot.
alright
(Got #1-3 of the method here from androidforums)
1)download mini-adb_tbolt2.zip from here: mini-adb_tbolt2.zip
md5: ef01f616471673d3eeb71b4cac4b8118
2)set up adb:
-extract miniadb_tbolt2.zip and place the unzipped folder onto the root of your C\ drive on your PC
-open a command window. windows 7,click on start bubble,type cmd in the search box and hit enter. a small black window should open up
3)in your command window: change to the tbolt2 directory by typing:
cd c:\mini-adb_tbolt2
4) then run the command adb reboot-bootloader
let me know what happens :D
Reactions: droid4eva
alright
2)set up adb:
got to the directory, but for srome reason when i try to run the commands i get " "..." " is not recognized as an internal, external or operable program or batch file..etc am i doing something wrong
update: installed sdk pack and now adb reboot-bootloader says error: device not found, the phone is and the that screen i posted is showing still not found
Can you copy everything that the command prompt says
Thanks
Sent from my ADR6400L using Tapatalk 2
Try this once you are in your adb directory
Adb devices reboot bootloader
That command should dump you right into the bootloader and from there we can get you unstuck
People with their knowledge as well as input here have made this thread simply awesome.
It's like a Rescue 911 call in thread form.
Eager to learn and see what the outcome is
Keep up the good work guys, and gal. :-D
Reactions: trter10-imore
ive installed htc sync and when i try to run it, no device found and when running comands i gert " error: no device found".
When i plug in the device to the pc it will say its a generic usb and a dialog box thats says this device can perform faster..
Any other suggestions?
Plug your phone into the PC. And in the command prompt line once your in your adb directory. Try this command
Adb devices
If the PC can see your phone it should show you your phone In the command prompt line box. If your phone shows up we should be able to save it if it doesn't you may be out of luck.
Adb devices
when i plug it in its acknowledged, only as a "generic usb". Ive tried all the commands I can think of, adb usb, reboot, reboot-bootloader, adb devices renders "list of devices" but theres nothing there; adb reboot recovery, and each time i get "error: device not found".
think at this point im going to send back to seller and resell the screen i purchased. unless something miraculously happens :(
If none of those commands are working then its definitely bricked. Hope the seller will give you your money back
yes I opened case not thinking it was going to be resolved and he's agreed to do so upon return receipt. sucks we couldnt get it working. im usually good with this kind of thing. oh well, on to the next.
and thanks to everyone who has helped me along the way
Sorry we couldn't get it working
But i sent you a PM that might give us some hope
Hi all, :) I went thru what the OP did, same weird icon, but got to the bootloader screen using down and power button. Now I'm not sure what path or paths to do on this screen. If anyone will help, it would be much appreciated.
do you have an sd card adapter? Does the bootloader say S-OFF or S-ON?
Alright, if you put this file on the sdcard as PG05IMG.zip and boot to hboot, let it flash, you should be able to boot. Just make sure to remove it when you're done!
http://db.tt/z7zbekNa
Md5: 013CBDD3A9B28BC894631008FA2148E2
trter0-2 Thank you for the info. I got the file downloaded to my PC, took 45 mins, does that seem right? Will try to move it to SD card today and into the phone. So, when I go to the bootloader, do I highlight hboot and press the power button to flash this file?
OCMDDan
