Is it bricked, or can it be fixed?? Help ASAP please!!
[ Will try to move it to SD card today ]
I moved (using drag n drop) the file to SD card, but says 'no image'. Was I suppose to move to SD card with WinZip, thats what it downloaded to. When I try to open file on PC with Winzip, I get an message: 'error: Central directory not found'. I am a nube, but can follow step by step directions well.
Thank you again, it is trying to activate. I pulled the battery n the SD card and have restarted a couple times, looks OK! :D In the above instructions, when in hboot I also had to choose Recovery under Fastboot.
so its working?
Sent from my ADR6400L using Tapatalk 2
I think so. I can't get past the activation screen without activating it. The phone is not for me, it's for resale. Is there a way to get to the home screen w/o activation?
Just go throught the activation, do what you need to do, and then factory reset.
Can I do a factory reset from the bootloader if I don't activate it?
Sent from my SCH-I800 using Tapatalk 2
doxidex23
