Is it possible to connect an Android phone to a 10Gbps Ethernet?
  • Start date Start date
A
Android Central Question
I have an adapter that I can use to connect my Android device to the router through the Ethernet port. The problem is that this adapter is just 1Gbps. I have searched but I could not find any adapter that supports 10Gbps. Do you know an adapter that supports it?
You have more than 1 Gbps internet? You're moving enough data to/from your phone over your network that you need that kind of speed? If you're looking for it just because your router supports it, I can certainly find better ways to spend $150 or more. MOST network ports/switches are backward-compatible, slower speeds should work fine. A quick Google search revealed several options for those USB-C 10 Gbps network adapters. The challenge is that they're not just dongles, they appear to be somewhat hefty boxes...
If you need additional help or have more questions or details to share, please join the site so you can reply in this thread. See this link for instructions on how to join Android Central.
niv141
