Is it safe to frequently keep / remove Huawei P30 Pro on wireless charger?
  • Start date Start date
A
Android Central Question
Is it safe to frequently keep / remove Huawei P30 Pro on wireless charger or any other wireless chargeable phone for that matter?
The only thing he left out:
Wireless charging pads, like everything else (except, possibly, the Big Bang) are less than 2100% efficient, and that difference is dissipated as heat. If the charging pad id a stand, most of that heat goes up and doesn't affect the phone. But a flat charging pad's heat also goes up - right into the phone - heating the phone more. So a semi-vertical wireless charging stand is better. (And you can charge to even 95% as long as you don't discharge past 50%. As you get close to 100%, the battery is getting pretty hot, and if anything goes wrong, you can bake the electrolyte out of it, which isn't a ood thing.)
The advantage of a semi vertical stand is you can use the phone comfortably while it is being charged.
Such a charger with a fan is even better to keep the phone cool.
dknaturesgardencbd2025
