Is Jellybean on your Sprint Galaxy S3 yet?
This pops up.
Sent from my Samsung Galaxy S III using Android Forums.
Yes it is!
Battery drain is horrible.Restored to stock NO APPS still battery drain i can watch the % drop.I hate this update.Took that long and they can't get it right.Going back to ICS. At least i can have a battery life.If were going to be beta testers for Sprint/samsug/google then why take so long to release it.
Can you please give me the link for the manual update. Does it work good?
Sent from my GT-N8013 using Android Central Forums
This will be the way to manually update your phone if you are:
Rooted or Unrooted - Stock Rom with all needed bloatware and Stock recovery.
Download the following update zip and place it on your external sd. Go to settings/security and make sure unknown sources is unchecked.
Shut off phone. Press volume up, power and home button at the same time. As soon as you see a flash, let go of the buttons. This will put you in stock recovery. Using the volume bar to select and power button to activate, select update from external storage. Choose the file you previously put there. Push your power button. Your update will begin.
And here it is at last....
UPDATE ZIP IS HERE! And yes it works.
I would like to thank skiskilo and mdmitchell13 for continuing to search for this long after I went to bed.
Yes, it works well. So far.
Sorry new to this, what Google link? Which thread?
Mines keep saying failed I used triangle to reset flash count, I used super user user to lose root access.. I can't get into no files that requires root access, update still failing
Perhaps its just your phone or else we'd be hearing about bad battery life everywhere with JB. Either way, hope you get it resolved!
Is Jellybean on your Sprint Galaxy S3 yet?? Hellz Yeah, by way of Manual Update..Why wait, you can do the manual right from your phone as long as you have a external sd card inserted.
Dreamz
