Is the problem with low notification and ringtone volumes fixed in Lollipop upgrade?
for3nsicguy
105
I have a bone stock and unlocked 6503 Z2 I use on AT&T. One of my few complaints with the Z2 is the known "issue" with unusually low volumes for notification sounds and ringtones in 4.4.4 KitKat. For those of you who have upgraded your Z2 to Lollipop 5.0.2, does the problem with low notification and ringtone volume still exist after upgrading to 5.0.2 or this issue fixed in the Lollipop upgrade?
Many thanks....
I'm having the same exact problem after upgrading to Android 5.0.2. The ringtone is totally silent regardless of which ringtone is selected. Adjusting the volume has no effect. Any solutions yet? It's truly perplexing as a ringtone is a very important feature on a smart phone.... :(
I am having the opposite problem lol It's all too loud but I have solved a issue like yours before by switching flight mode on for a few minutes. It's worth a try :) Flight mode fixes lots of problems that you wouldn't think it would.
I have a problem with the rest of the crap the update left behind. I liked my phone the way it was, my way, lol I wish I hadn't upgraded now but, silly me, thought it was going to make my phone better! I really don't like the colours dotted all over the place and that I can't change it ggrrr. No one can hear me when I'm in a call, they only hear static which has been really stressful so I'm going to have to visit the service centre I suppose. I hope you get your volume trouble sorted out soon :)
After having a terrible experience with Lollipop on a Moto X 2014, I was very hesitant to upgrade the Z2 I got to replace it. I really liked the Z2 on 4.4.4 KitKat with the exception of the low notification volume bug.
I upgraded my (unrooted and completely stock) Z2 over the weekend using Sony's PC Companion software. After the upgrade, I used the PC Companion software to perform a "System Repair" which completely wipes all traces of the previous operating system. I wiped and reformatted my SD card prior to the upgrade. This way, I wiped the phone of ALL traces of any previous operating system data and set it up as a new, pristine Lollipop device.
Here are a few observations after a couple of days with the Z2 and a fresh install of Lollipop:
1. The notification volume bug is fixed. I have used the same mp3 files for custom ringtones and notification sounds for several years. They are now as loud on the Z2 as on any other phone and louder than most.
2. The battery life will take several days to settle in, but even on days 2 and 3 I had 45%-50% of my battery left with 3-3.5 hours of screen on time after a 17 hour day. Not as good as I was getting, but better than most phones I have used.
3. The Lollipop experience on the Z2 is MUCH better than it was on the Moto X 2014. None of the jank and lag and stutter I experienced with the Moto. (And yes, I did perform a factory reset on the Moto X 2014 after the upgrade.)
4. I had no issues with call quality. If anything, it is better now than it was on 4.4.4 KitKat.
5. I still don't care for all the ridiculously bright colors in Lollipop, nor do I like every menu and settings screen to be on an all white background. Alas, Lollipop is what it is. If you want the latest features...
I spent a lot of time in Sony's Z2 support forums and on other Z2 message boards before I performed the upgrade. The consensus seemed to be that quite a few people who upgraded from 4.4.4 to 5.0.2 had problems with their Z2 after the upgrade UNLESS they performed the "System Repair" with the PC Companion software and wiped all traces of previous data from their device during the upgrade. I'm not saying it will fix every problem, but it certainly worked for me.
I am much happier with my Z2 after the upgrade...even if I liked the look of KitKat over Lollipop. The Z2 was fast on KitKat...it is faster and smoother on Lollipop.
I was able to perform a system repair as well and all features work properly. I haven't noticed any significant change in battery life. I'm a happy camper again :cool:
Glad to hear it worked for you. I was hesitant to upgrade but really glad I did. Overall I am very happy with the Z2 on 5.0.2.
Now if we can just get Sony to push the 5.1 update and get the Lollipop memory leak fixed...
