Is there a big difference in battery consumption when using cellular data vs WiFi?
larry1076
56
If you're battery is getting low and you want to conserve energy as much as possible, and you have a choice of using data either on your 3g/4g network or connecting to a WiFi network, what should you do?
christian shook
3
Based off of what I've seen cellular gives a better battery life as long as WiFi is off for some reason I get about an hour to three hours more on cellular also some times a connection Will be lost with WiFi so it searching tends to drain it which I noticed on my iPhone but on I now have a droid turbo and cellular is still the way to go when it comes to battery life
Sáenz
