Is your Droid protected?
I have the Innocase, which I love. I also just bought the leather side case from VZW and the Innocase is sufficiently thin that it slides in and out without difficulty, although the case needs a bit of breaking in.
Naked is nice, but I'm taking extra care of my Droid, even though I have insurance.
I'm using the VZW leather case. I usually wrap my Droid in a thin microfiber cloth before it is stored in the case.
I use the invisashield on the screen... On my other three Droids, I had it on the full body and I have the kit here to do it... But it really sucks for the most part... Would be usefull on some parts but others just make it catch on everything... I keep it in my pocket and it tends to just peel parts of the back and sides off..
im seriously thinking of getting the zagg full body...does anyone have this yet?
Yep, I'm sporting it on my Droid. Although the screen protector part was defective with mine (had a pit in the middle of it that couldn't be removed), so I just left that part off (the screen is made out of tempered glass and should be quite durable).
Prior to the full bodied Zagg armor..... I was sporting a slim black case found at my local Best Buy. It was a nice case, but the top portion kept on popping off and being I have both the media dock and car dock, I had to constantly remove the case in order to used both.:rolleyes:
I strongly advise getting the Zagg armor. Not only does it keep your Droid slim and protected, but it also provides a nice textured surface that provides grip and enables you to use both the media and car docks.;)
easeasea
