issue with my evo
taguluchi
177
11
I have an issue with my evo that when i go into the sidget menu and go to htc widgets for the coin flip widget it says its downloading ....its been like that for the last 4 months I dont even want the coin flip widget ......any ideas how i can get the download unstuck or to how to stop it from running because on spare parts it say HTC DM has been using up most my battery
From the home screen if you hit menu settings then application if you go under manage applications is it showing up there or under running apps. If so you should be able to uninstall from there?
yeah i did both of those, it seems like that should have stopped it but it didnt and that was 2 days ago
Thats always an option....jusr remenber to save everything you have set on ur phone before u do
Hmm...it won't let you cancel the download from the market either?
realjordonjacob
