I've got an LG G Pro 2, you've got questions ? fire away!
Re: I've got a G Pro 2, you've got questions ? fire away!
Is the bootloader locked? My note 3 is locked down tight, and I'm done with Samsung if this LG is unlocked (bootloader)!
Again, I've got the Korean model.
Phillllll!!!
You have my dream device in your hand.. i love my LG G2 like no otha, BUT i want bigger, better, faster, stronger, and the LG Pro2 is it!!!
Does it have the ability to change the transparency when you make an app mini so that you can operate apps UNDERNEATH the window like LG G2?
thanx!
BTC
Will check in the morning, but I don't recall seeing a setting for that.
Will the LG G Pro 2 support 128GB microSD cards? If not 128, then how about 64GB?
ok ty... its NOT a "setting", tho, its the little slider on the app that you minimize that makes it transparent and allows you to tap things that are underneath the window...
( skip to 3:49 )
Also, i know it doesn't doesn't have wireless charging like O G Pro did, but do you think there will be some gizmo to allow it to have it?
ty!
BTC
Re: I've got a LG G Pro 2, you've got questions ? fire away!
Hi Phil! Can you tell me if the Pro 2 has qi charging? Or if you know of any plans of LG's to add qi via a replacement battery door? Thanks?
When playing game, G2's heat really close to unbearable. Really uncomfortable. The heat center is on the back button which I assume the cpu behind it. How about G Pro2?
Sent from my LG-D802 using AC Forums mobile app
Phil,
Are the back volume keys and power button less or more awkward on the larger form factor? Or about the same?
My next phone is going to have an IR Blaster and 3GB. I know it has the 3GB, what about an IR Blaster (or is it likely that an IR Blaster will replace the TV antenna space)
IR's in there.
Not with the phone I've got. Don't know about any future plans.
https://www.youtube.com/watch?v=vs23w4S41CQ&feature=c4-overview&list=UU-xOxPoQXnvEQKqkucrM_Cg
( skip to 3:49 )
ty!
BTC
That's a different feature. I'll do a new video today showing Mini View.
So to summarize. LG G Pro 2 is "better" than the LG Flex in display, camera, memory etc.
LG G Pro 2 is pretty much the same hardware (minor differences that mere mortal's wouldn't notice) feature set wise as the Note 3 with the major differences being Stylus vs back buttons.
Samsung pretty much beats everyone on software creativity, usability and features.
I would really like to see you guys do a new Phablet show down. Note 3 vs LG G Pro 2 vs LG Flex vs Sony Xperia Z2 vs HTC One Max (or whatever they announce this month) vs any other's I missed.
Tell you what, get me some review phones and I'll write it for you :D
Winner take all (my money)
Does the slow mo (high frame rate 720p) video have a similar feature to the Z2 where you can select which regions of the clip are in slow motion and which are in normal motion? Also, after you've taken a video with the high frame rate mode, is it all a slow-motion file or can you choose a payback speed?
The iPhone 5s records at 120fps and allows you to select the parts that you want in slo-mo. Its a great feature, do any other Android phones have this feature.
~S
Pssssst. BTC.
lol, ty but thats just to make "one handed use" easier...
my question (focus Phillllll!! ) is when you hit the little x on one of the Qslide apps, does it still have the little slider across the top of the app once its miniature allowing you to "reduce the transparency" thereby allowing you to tap on app or widgets UNDERNEATH that its placed on top of... (did u watch my vid & skip to the part @ 3:49?" : )
ty!
BTC
ty!
BTC
I am not gonna lie, I am so confused.
ty!
BTC
Ohhhhhhh. Yeah. That's still there. :p You can change the transparency.
Do you know if features like split screen and adding the multitasking button to the button dock will make their way to the G2 via an update?
Not sure. Split-screen, maybe not, because of the display size? (That's just a guess.) The new buttons, though, that wouldn't surprise me.
Tfunz
