I've got an LG G Pro 2, you've got questions ? fire away!
Re: I've got a G Pro 2, you've got questions ? fire away!
i saw in a picture how you can change the menu button to the multitask button, if you can what will happen when you long press on the home then?
Nope. You can add the recent apps button, but not swap out the menu button.
The menu button is always there.
How does the speaker sound in the G 2 pro?
And any word on if or when it will hit AT&T? Best guess? What do you think the on contact price would be?
How are the speakers? Could you upload a video of it playing music and also playing an intense movie trailer? I'm curious how it works as a media device since it doesn't have front facing stereo speakers. Also, how is the GPS lock-on speed? And one last one, how is signal strength in dBm compared to some other comparable devices on hand, if that's possible to compare with the Korean version. Thanks!
Does the slow mo (high frame rate 720p) video have a similar feature to the Z2 where you can select which regions of the clip are in slow motion and which are in normal motion? Also, after you've taken a video with the high frame rate mode, is it all a slow-motion file or can you choose a payback speed?
Be honest.... Note 3 or this?
Will it blend?
1. Does it do that weird breathing on focus that plagued my g2?
2. How is the sound on video recording? I found it unclear on the G2?
3. Can I have it please?
What do you think are the chances that we will see the G Pro 2 in Verizon stores? We know that they Opted not to have the G Flex so could the Pro 2 be their next LG follow up to the G2?
Loud. Not as full as the HTC One, but loud.
No idea. Either it happens or it doesn't.
I'll get a video up for you on Wednesday.
No idea, but that AT&T had the original probably doesn't hurt.
Is the bootloader locked? My note 3 is locked down tight, and I'm done with Samsung if this LG is unlocked (bootloader)!
Me too! Galaxy s4 on AT&T is locked tight. So, I'm hoping it's unlocked, but not counting on it.
Aight, folks. Let's hear 'em. What do you want to know about the G Pro 2?
Phillllll!!!
You have my dream device in your hand.. i love my LG G2 like no otha, BUT i want bigger, better, faster, stronger, and the LG Pro2 is it!!!
Does it have the ability to change the transparency when you make an app mini so that you can operate apps UNDERNEATH the window like LG G2?
thanx!
BTC
Tfunz
