I've used the LG V10, you have questions. Have at me!
Although our local Verizon stores still do not have any of these to sell, one of the stores finally got in a black display unit. So I was able to get a hands on and try it out. I am coming from a little over two years with a Note 3, which overall was pretty good. So my comparison for a new phone has been between the v10 and Note 5. A couple of questions for those that have used the v10 for a time now.
The Samsung has the power/screen off button on the side. The v10 on the rear. So, different than the Note, you actually have to pick up the v10 to wake it up or off the screen, correct? Or does the screen tapping thing I have heard about, but never used, do it?
The display model kept waking up the screen every time after turning it off. I would turn it off and leave it alone, and a second or two later, the screen would come on full brightness. Maybe this was just the way they had the display unit set up? But I am used to turning off my Note 3 screen and having it stay off until I turn it back on. Has this been an issue for you?
One other thing I noticed: In a side by side, the Note 3 actually has a little more screen available. The v-10 appears to be the same size plus the ticker screen, so would seem bigger. But the v10 has the menu, etc. buttons dedicated to the lower 1/2 inch of the screen so that can not be used for anything else. The Note has physical menu buttons below the screen. When I held them side by side, the v10's main screen usable area was actually about that 1/2 inch smaller than the Note's.
Tough decision between these two. My last two Samsung phones have been OK, but I have grown a bit frustrated with the interface changes and the very slow updates to software. Plus I find I never use the stylus. Those things plus the lack of storage and removable battery have me seriously considering the v10. Although the battery issue may not be a big deal. I think that I, like many, remember the old days when removing the phone's battery was the only way to fix a problem and have a tough time thinking about owning a phone without the ability to do that.
Oh, and side by side, I thought I could see that the Note 5 had a better looking display. Seemed more saturated and sharper at least in the store. But they both looked good and compared to my Note 3, they are blazing fast.
"So, different than the Note, you actually have to pick up the v10 to wake it up or off the screen, correct? Or does the screen tapping thing I have heard about, but never used, do it?" You can wake or turn off the screen by tapping the screen as long as you use the stock launcher. If you use Nova Launcher or some other third party, the tap-to-turn-off no longer works, but the tap-to-turn-on still does. I came from a Note 4, but I'm already used to the button on the back and actually prefer it. The fingerprint scanner is in just a perfect placement.
"Maybe this was just the way they had the display unit set up? But I am used to turning off my Note 3 screen and having it stay off until I turn it back on. Has this been an issue for you?" This hasn't happened with my V10, so must be something they have set on their demo unit, or perhaps that one is defective.
"One other thing I noticed: In a side by side, the Note 3 actually has a little more screen available. The v-10 appears to be the same size plus the ticker screen, so would seem bigger. But the v10 has the menu, etc. buttons dedicated to the lower 1/2 inch of the screen so that can not be used for anything else. The Note has physical menu buttons below the screen. When I held them side by side, the v10's main screen usable area was actually about that 1/2 inch smaller than the Note. " You won't even notice the difference once you use it. And the software buttons go away when using a full screen app, which ends up giving you more screen available than the Note 3 does.
Overall, I'm happy with the V10 after the few days I've had it. Not enough time to judge battery life, but I've gotten through a whole day pretty easily with only plugging it in in the car on the way to and from work and such. I love that it doesn't have as much bloat as Samsung did. There are some apps from LG (calendar, LG Health, LG Backup), but nothing like making me have that PEN app that is literally just drawings people uploaded that I have no use for.
Its easy to set up Nova to do the tap to turn off the display. I installed one of the 50 free "turn off your screen" apps on the play store and assigned it to the double tap gesture.
Good to know. I personally don't *want* the double tap to turn off because it interferes with my live wallpaper which lets you change the current picture by double tapping the screen, but it's certainly a way to go if one needs it!
The two phones are very different, so the decision should be simple.
The Note 5 has a sexier build and a slightly better screen. And the stylus.
The V10 has a more robust build, expandable memory, replaceable batteries, and the second screen.
I've been a Note user for three years, and would have autoupdated to the Note 5 if it wasn't for the fact that its a fragile phone with no SD card slot and no replaceable battery. At that point, it dropped to fifth on my list of possible phones to get.
The V10 came out on top, but I would get the the Nexus 6P, the Droid Turbo 2 or Moto X Pure before I would get the Note 5.
You could also use a different gesture to turn it off besides double tap. Nova launcher supports a long list of gestures.
Thanks everyone! Just about ready to decide on the v10. Wish it was in stores here, but ordering online has worked OK for us too in the past.
edit: Just checked again today and they got just one in. But it is white and I want the black. Oh well.
That's true. I honestly haven't looked much into the gesture features of Nova. Maybe I should do that.
EDIT: Oh! Found out that you can still double tap the notification bar at the top and it will turn the screen off and that works in any app, not just the launcher. No need to set Nova differently.
I had only bought black phones until I saw the White and Gold V10.
It is striking.
The black and Gray version is nice too but doesn't stand out.
It looks like most other phones.
My compromise is a case.
Spigen has a dark gray case that I like and I can still go without on occasion to show off.
Yes you enable a knock code...I was worried about this too until this worked for me
Some youtube reviewers say that there is a problem with the fingerprint sensor and some cases ,that influences the function of the sensor.
Any thoughts?
Some people are having an issue, but others work fine with the same case. It's hard to tell how pervasive the issue is.
So what shall i do? Buy it or wait a while until this issue is being covered?
Mine works perfectly, and the V10 is the greatest phone I have ever owned. If it was me, I would take a chance. Just remember that if you are going to use a case, program the fingerprint with the case on.
I would buy it I have no problem with the INCIPO case from the T-Mobile. store. I always get a case before I leave with a new rig. Aloha
Lots of good info here. My question is, is the battery from a G3 compatible with the V10? I still have a new battery from when I got the G3.
Phil,
I'm trying to decide between the V10 and the Turbo 2. Which do you like better? Which camera took better pics? I know the Turbo 2 has a higher MP but which sensor actually does a better job of good, clean, color accurate images? Which one felt more reliable? On paper, it looks like the Turbo 2 is more powerful but which user experience is the strongest and more reliable in your opinion?
I'm New to android. How do I add fonts to the phone or add themes? Can you change the text msg bubble color?
bassey
