Jelly Bean 4.2 Camera
Damn. I can't wait to get this feature rocking!
Sent from my Galaxy Note 2 using Tapatalk 2
anyone using a HTC Desire HD here?
For mine, it seems that the gyroscope is moving really really slowly. in photosphere, the green dot moves very very slow. anyone else having similar problems?
awesome stuff! works like a charm running on AOKP milestone 1!
only slow thing i noticed is when shooting a video and you take a picture, some lag in between. just waiting now for the photosphere view in gallery app
Do we need to remove Gallery2.apk before flashing the updated zip? Or just flash the zip over everything?
ah crap, changed the permission to RW-R-R and rebooted, stuck on loading the OS :S currently using CM10 Galaxy Nexus GSM
HELP!! should I just wipe data and install again??
Dirty flash your rom and gapps. Do a system wipe for extra paranoia/safety.
ahhh .. tried to fix the permission through clockworkmod, didn't work so will do system wipe and dirty flash my rom and gapps, cheers...will let you know if it works :)
Yeah don't do fix permissions. Fix them manually in Root Explorer.
Just flash that updated zip.
Meanwhile tiny planet mod.
Pickle240
