Jelly Bean 4.2 Camera
The stock camera is going from portrait-mode to horizontal-mode even if auto-orientation is disabled. I liked this feature very much.. Now i have to enable auto-orientation before taking a photo, otherwise the cam will stay in portrait-mode. This version here is great and i love the work you are doing for us..Thank you!!!
But is it possible to add this feature to this 4.2 cam, too?
Beats me. That sounds like it would take some time to figure out, so I'll hold off on final judgment :).
The updated zip is working flawlessly! I removed Gallery2.apk, wiped cache and davlik, and flashed. No FCs and everything seems to be working. The new photo editor is great too!
Maybe adding the setting android:screenOrientation="sensor" to the right activity on AndroidManifest.xml
I like the older way of editing photos mo betta. New camera is good but I prefer the fine tuning as opposed to Instagrammy filters.
Works fine until I take a normal picture. Camera freezes and then when I try to go back to the camera I get a ''cannot connect to the camera '' ' message. Only way to recover is to restore my nandroid.
Same, I'm using the newest flashable zip on ATT Galaxy S3
Yeah don't do fix permissions. Fix them manually in Root Explorer.
ugh, taking ages and my battery more or less died because I took my battery out so many times and updating CM10 to latest version. I will make this camera function work!!! lol
Don't know if anyone is interested, but this works quite well on the Nexus S!
I've used the first method and the PhotoSphere is not working as discussed above. However, flashing the updated zip gets the PhotoSphere working or not yet?
For those of you having issues even after following all of the directions.
Go into system/app, and see if you still have the .odex file that goes with the gallery .apk file. If you do, delete it, or rename it to .bak, but get rid of it. It should stop the force close issues.
Those of us that are rooted but still running the stock non-deodexed rom will have this issue, as the .zip files don't remove the odex file when they flash.
Have you tried a build.prop edit to see if that works?
I'm getting the same error on an HTC One X (AT&T). Everything else seems to work fine after flashing the zip (Paranoid Android 2.51). What edits should I make to build.prop to spoof a different device?
General instructions:
Grab .apk and those 3 lib files. Push/move apk to /system/app and push/move the lib files to /system/lib.
On all of those files (so 4 total), make sure your permissions are RW-R-R. Long press on the file, go to Permissions, and make sure it's Read - Write for the top and Read and Read for the latter two.
Reboot and everything should work. The only bug right now, aside from stuff with video that I haven't tested, is the inability to view Panorama photothings on the device--you'll need G+ and a browser for that.
Jackwills2567
