Jelly Bean 4.2 Camera
Not sure if this helps or was said before, when trying to push the view panorama button, it gives this in the logcat:
D/LightCycleHelper(22005): PanoramaClient not available.
i cant take video with this....after pressing the red REC button, nothing happens..weird
Cannot confirm - video is recording just fine... However, all the cool effects on camera (big eyes, big nose, etc.) has been removed (or it's just me who can't find them...?)
Tried in on a S2 Skyrocket running CM10 4.1.2, no FC's, camera works, panorama mode gets to the end but fails to save the file, filters and editing works, gallery works, 1080p video recording records garbage, 720p recording doesn't save a file. I wasn't even expecting this much to work, so I'm pleased! I didn't try any build.prop edits, and to install I didn't use the provided libjni_mosaic.so as I already had one.
anyone using a HTC Desire HD here?
For mine, it seems that the gyroscope is moving really really slowly. in photosphere, the green dot moves very very slow. anyone else having similar problems?
Same here on my DHD, works but very slow to line up points.
UPDATE: dirty flashed my rom and gapps, pushed the .apk through root explorer, changed permission, still having the same issue...still stuck on loading screen!!
I always get a FC at the end of rendering with PhotoSphere. Gallery closes. Result is that I don't get any 360? Panorama pictures :( I used the latest ZIP file
not showering up for me. Running Bugless Beast 4.1.2 ROM. All permissions have been changed and moved to systems/apps folder.
Oh well, at least I have Gmail 4.2 and keyboard 4.2
i'm on aokp jb m1 i9100.....i cant eems to record any video......after pressing the rec button, it didnt show any timer, cant see any video file in gallery as well...
It works wonderfully on G+ in the browser on my computer.
This isn't working for me. I've been able to take a couple of photosphere pictures which, as expected, show up only as flat panoramas on my device. I've shared them with my Google+ app, but even then they only show as panoramas (when I view the post in the browser). How are you getting them to work in Google+?
Use a computer.
Sent from my Galaxy Nexus using Xparent Cyan Tapatalk 2
Reboot?
Yeah, instead of install since we aren't supposed to do that. I'm going to delete the files and try again after this meeting. Work always gets in the way of the important things, ya know?
Yup. I'm dropping off the face of the planet after lunch. Buckle up, AC.
Just flash that updated zip.
Meanwhile tiny planet mod.
How did you managed to get the photo with the tiny planet effect? using the Photo Sphere or other software?
Later edit: Nevermind, in order to use the tiny planet method you have to do a full panoramic photo.
Ashok Dharshan
