Jelly Bean Bluetooth Voice Dialing is totally useless
More ample feature set?
I think so, at least compared to the last time I used Cyberon. I'll just list the Voice input commands/features/capabilities in Voice Control, and you can tell us how it stacks up against Cyberon. Last time I used Cyberon, its Commands were limited, but perhaps it has been expanded.
I've tried most, but not all of the listed Commands in Voice Control. The only one I've tried that doesn't completely work is the Signal Level command, which works fine for 3g, but doesn't properly report for 4g/LTE signal levels (on 4g/LTE, it always reports No Signal). Luka apparently has no LTE available for him in Italy to resolve that one.
STANDARD ACTIONS:
Add Note to Evernote
Add an Alarm
Add an event
Battery Level, includes whether it is on the charger
Call
Close Navigator
Compose (Dial) a number
Listen to
Lost Calls
Navigate to
Send a Message (Text)
Send an email
Signal Level
Start (Launch) application
Tasker , execute Tasker task
Unread Messages
What Time is it?
SPECIAL ACTIONS:
Back
Confirm
Help
Multiple result choice
Quit
Repeat
I know this is a bit of a Ford vs. Chevy discussion. Both apps are useful, and we each have homed in on the one we like the best, and find the most useful and reliable. I don't expect we will convince each other to switch, but perhaps this discussion might help inform potential new users, and they can compare for themselves.
Performance may vary with configuration. I"m using Voice Control on a VZW Galaxy Nexus, on Android JB 4.2.1 MMuzzy ROM with SVOX Classic TTS, and a Motorola Roadster 2.
Cheers:)
Sent from my Transformer TF101 using Tapatalk HD
No, voice control apparently does do a lot more than cyberon. While cyberon will launch apps and tell the time it is primarily for voice dialing. I'll check out voice control sometime. In the meantime cyberon remains my daily driver because it is just so good at bluetooth voice dialing. Google has tortured voice dialing so much in the last 6 months or so that I'm just really happy to have something that works reliably again. Thanks for the info on voice control. Sounds like you also have a winner.
I thought the whole point of an update was to fix things that were broken and to make things better. But maybe I have it backwards. The phone dialer on my HTC One X fresh out of the box worked great with my blue tooth device. But since the update to Jelly Bean it stinks. I would Really REALLY like to go back to the original dialer.
Disabling google search in apps, all apps, may be all you need to do. You will lose the use of google now while its disabled and a few other things but you can easily re-enable it if you just want to try that as a solution. That used to make it revert to the original dialer and it probably still works. I used that method until I got the use of cyberon back and it was worth the tradeoff.
My problem is a little different and I am hopping that someone has come up with a solution to this. My Bluetooth headset worked just fine before the JB update but after the update when I push the button on my headset the phone voice goes through the phone speaker and not the headset. After the call is connected then the audio goes through the headset.
Has anyone else has this problem? I was wondering if I got a different headset if that would fix it but I don't want to get another headset if that won't fix the problem. I have an HTC One X phone. With JB 4.1.1
Hi everyone. Yesterday I got and update to Google Search and after this update my bluetooth voice dialing started working again. :) So if your still having problems check in Google Play for the "Google Search" update.
TheGreatApe00
