Jelly bean ota - who got it?
I started pulling the update around 23:30 CDT. Still dling because I am using craptacular WiFi at my parents. 512KBS is the Max speed out here and you know that isn't happening. I can't sleep until I have JB running... I just can't.
-Edit-
As of 01:50 CDT I finished installing the update. Click to view quoted image
And with that I shall cuddle with Google Now.
Sent from my Galaxy Nexus
Thanks for Bragging!!! Lol j/k I am glad someone got it. Where are you, location that you got yours.
did the framework move 3 times.....yayyyyyyyyyyyyyy Thanks a ton for sharing the tip...its downloading now!!
Just got it after 5 framework stop/clear. It is awesome compared to 4.0.3.
Vodafone Ireland.
Updating now, sweet!
Cleared framework 5 times, then decided to reboot as someone did earlier and voila, update appeared automatically, didn't have to 'check for update'
Great start to a Friday!
Had done the clear framework/check for updates trick umpteenth times over that last 3 days (yakju 4.04), but didn't work until today.
Rebooting now! :D
How long should the download take over Wi-Fi?
I don't see a progress bar...
took only a few minutes at my house.....less than five I would say.....seemed fast anyway
Mine took less time to download than it did to install. Maybe 5 minutes for the download and 10-15 for the install process to complete.
I'm already at 15mins and nothing seems to be happening
Is there no progress bar?
Yes, the progress bar is a thin blue line at the top of the window that says you have an update, when finished you will get restart button.
I went to Settings -> APPS ->Google Framework Services and cleared data and hit "Force Stop. When I went into check for update JB 4.1 began downloading instantly on the first try!
Reactions: cresto2
Finally!! Did the framework trick / check updates several times in a row, repeatedly and quickly...and finally it worked!:D
Did apps > all apps > google framework > force stop > clear cache and on the first check for update it was there. Now got some yummy Jelly bean.
Great tip about clearing framework data but I was getting it wrong so as someone else pointed out make sure you clear data before force stop. Once I did it in that order and then checked for update it started download JB immediately. Make sure when you do it you are connected to a wi-fi network.
It's worked for people both way. I don't think it really matters, just so that you do both.
I am downloading as I type.
Edinburgh, Scotland
I did the clear framework, etc a few times, and suddenly it appeared.
Nearly freak me out (I wasn't expecting it to work :) )
BarishYadav
