Just got my Galaxy S3, need advice!
I'm wondering whether your problems couldn't be due to a conflict among apps. How many have you installed. My GS3 runs fine, but my GS2 used to get terrifically hot. I discovered the contributing factors were: (1) not enough air circulation when it was in the case, but only when it was already getting warm from the next 2 factors; (2) using Wi-Fi on Froyo and Gingerbread--problem went away on ICS; (3) 3rd-party app conflict. The app factor was the most difficult to figure out. It was never something obvious, such as two games conflicting. It was always something unexpected, such as a game conflicting with the calendar app.
So, there may be solutions for your problems, but it won't be easy to troubleshoot them.
Sent from my GT-I9300 using Android Central Forums
how hot are we talkin though? androids do get hot when say downloading a large file or stream or play games especialy while plugged in.
op should get an app/widget that measures battery temp.
my overclocked zte blade used to hit over 50?c without problems (other than sweaty hands lol) :)
global s3, UK. Ask me anything and ill reply even if its just an intelligent (or crazy) guess ;)
That's the thing, I also assumed it was an app confliction but I had wiped all the data using the recovery mode and just re-tried like running Temple Run, and it still froze once or twice.
I've been also using WiFi foe like 90% as I've been home for a while. Would that account for the problems?
It gets like warmish-hot, especially towards the bottom. Especially when playing Temple Run, like it just freezes randomly and then I'd have to go to home, and close it and relaunch it.
Oh! I also watch Naruto Shippuuden right, so I downloaded the latest episode, EP280 and its 720p (I've seen people playing 1080p of the Sam series easily) and it'd play fine then suddenly like 5-10mins in, it'd freeze. I use MX Player and tried others and same thing.
I just generally thing it's a faulty device.
think i agree mate unfortunately :( hope you get it replaced without any hasstle man. good luck :fist:
Make sure that Power Saving mode is not active, that is probably what is making your S3 lag.
dhickman
