Just Works ROM v1 - On Hold Until Further Notice
Status
Not open for further replies.
Re: Just Works ROM v1 - Coming July 25th
Not wanting to sound rude or disrespectful to your work, but you might want to check your grammar (and syntax) in the UI. Personally I would never continue after that introductory screen. Just be brief and correct. You also don't need to brag about your software to the user who has downloaded it and about to run it. Again, no offense intended.
All good, I will try to work on it later when I get stuff figured out.
I wasn't able to compile it, I have it slapped together and all I need to do it run it within Visual C++ but nothing is really cutting it.
Not to be a arse jerk, but you do know that you can't compile for Android in Visual C++, right? Nor for the ARM architecture.
You wanna compile natively for Android? Well you need the NDK for one. And a decent toolchain. One is included in the Android NDK, but I prefer the CodeSourcery toolchain.
EDIT: Also, where is that recovery and kernel you stated was going to be released?
not to sound skeptical about a project that one day says "i know you guys think im nuts but this is forreal" and the next day "on hold til further notice". i hope my doubt are wrong but i guess only time will tell.
Alright shows over, nothing to see here.
@OP - If you want to release anything make sure source is available as Jerry indicated per GPL agreement (might want to brush over that prior to releasing anything). If you decide you want to release something, just report this thread asking for it to be opened and I'll do so.
Status
Tfunz
