[KERNEL][GB] GingerKernel v08.1 (OC) DOUBLE-TAPPING BUG FIXED!!!
Status
Not open for further replies.
Re: [KERNEL][GB] GingerKernel v07.1 (OC) SD CARD ISSUES FIXED!
[NOTE]GingerKernel v07.1 Release:
Remember, msm7k is NOT the default governor, you will have to set it manually.
[/NOTE]
Hi, I'm on gRom2.2 and I was wondering what I need to do to set this governor manually? I'm looking forward to getting rid of the double tap issues. Thank you for making this kernel for us. :)
You can set the governor using No-Frills or SetCPU (I think No-Frills is included in gROM 2.2). Note that changing the governor will not necessarily get rid of the double-tap issues!
Re: [KERNEL][GB] GingerKernel v08 (OC) DOUBLE-TAPPING BUG FIXED!!
Here it is, kids! GingerKernel v08 is here with a host of new fixes and tweaks!
First, the double-tapping bug. This bug is a result of LG's sub-par software engineers. It is caused by the CPU spiking whenever the screen is touched. It has been fixed completely.
Second, the axis inversion issue. It is caused by LG's sub-par touchscreen digitizer, the MCS6000. The axis inversion workaround that I implemented in XioniaRedux is now implemented in GingerKernel. It is NOT an end-all fix, it is strictly a workaround.
Thirdly, it is POSSIBLE that the issue with some car chargers not working has been fixed. During the implementation of the double-tapping bugfix, the build failed at a source file that had entries for charging voltage that had indeed been changed since the 2.6.32 kernel series. I have not been able to test this potential fix so it may not be a fix at all.
Enjoy folks, and make sure to hit that THANKS or DONATE button if you haven't!
Oh and ROM Developers: rather than include GingerKernel in your ROM, please consider directing your users to this thread so they have the chance to thank or donate to me for my time and effort!
Been running this kernal for a day now, and WOW!!! Very nice work. This is another giant step towards stability like we had with ZVD.
Someone buy this man a Beer!!!
Updating NOW. Thanks SO much for this nupdate.
WIll Donate soon.
Reactions: G2k
Damn I wish videos worked with cm7. This kernel is very very fast and very smooth . Great job drew!
Thanks for the info. Just flashed kernel v08, I'm so glad the double tap issue is fixed, your the man. :)
i knew that we could count on you drew :):):):)
I have a 2-port 1A charger that stopped working after MVH. I just flashed V8 and it now works with the charger & screen issue is mostly fixed. Thank you for addressing LG's idiocy/incompetence.
-- Starfox
package the whole thing up, and email it to LG. It would impress them that a 25ish year old kid fixed, improved upon, and polished the kernel they "officially" released.
Truly, thank you Drew for you AND Team Hydro's work (jsntp, beezy, nick7, ksmithiny, and everyone else.) You have done wonders for our phones. We all appreciate your work.
The real icing on the cake is that I'm not even 25, I'm 21.
And on behalf of the team, thank YOU for using and appreciating our work!
haha even better!
drew walton/team hydro >= LG.
and way cheaper.
Thank you, Thank you, Thank you for fixing the double tap issue. If it were biologically possibly I would have your babies. But since it's not, you'll have to settle for a well deserved thank you. :)
You are MOST welcome. I'll have to pass on the babies, I'm not down to have little ones right now. But thanks for the offer! HAR HAR HAR HAR :p :p
kernel works great, thanks!
Wow, this is great!
A donation is pretty much required at this point.
Also, I'm curious about receiving FM radio (not streaming). I've heard our device has the hardware for it. What are the chances someone will ever get it working, do you guys think is it even possible?
Status
Ashok Dharshan
