[KERNEL][GB] GingerKernel v08.1 (OC) DOUBLE-TAPPING BUG FIXED!!!
Status
Not open for further replies.
Running at 806 and no double taps yet. Will report if I get any. Great job!!!!!!
Re: [KERNEL][GB] GingerKernel v07 (OC) SCREEN GLITCHES FIXED!
Just installed running great I'm at 825 an no reboots iv never been able to go higher then 806 before ill leave it here for awhile then ill move it up. No double tap an glitches or nothing so far will report if any. Way to go drew keep up the great work
Just flashed.running at 806 with no problem.Before, my phone would freeze at 806 on angry birds. Thanks drew , great kernel.
I'm not getting double taps either. However, after flashing this kernel, my SD card is not recognized in gROM ("your phone does not have an SD card inserted" when going in to the Music app, for instance). However, it is recognized in recovery (obviously, or I wouldn't have been able to flash) and it never had any problems being recognized with GingerKernel v06. Any ideas? If not, is v06 posted anywhere?
UPDATE: I found the stock kernel, flashed it, and my SD card is back to being recognized.
I couldn't tell you why that's happening but I do know that SD card issues have been reported with ZVH in general. Pretty sure that's not a kernel issue.
I know that there have been SD card issues reported with ZVH, but I personally have never experienced them, either on stock kernel or any of your other kernels. Then I flashed v07 or this kernel and the SD card disappeared. It was recognized in recovery but not fully booted up in Android. Flashing back to stock kernel or dirty flashing gROM in order to go back to v06 of this kernel immediately fixed the problem.
I flashed v07 again to see if it was a weird one-time thing, but the same thing happened again - The phone thought that there was no SD card. I popped the SD card out and the phone recognized that I had removed it. So I popped it back in and went to "SD Card and phone storage" and manually mounted the card, and the card was successfully mounted and able to be read by the phone. Very strange. I rebooted and the card again was not recognized, but going through the removal, reinsertion, and manual mount works every time.
So this may be the SD card issues people are experiencing with ZVH, but I am only experiencing it (and always experiencing it) with v07 and nothing else. It's not a big deal since I don't reboot much, so I can remove and reinsert when I do...just wanted to give more detail on what I'm seeing.
Thanks for all the work!
I had the same problem with the sd card not being seen with this kernel when I first flashed it but after a reboot it went away and hasn't returned. Maybe that will work for you.
Opps, see you already tried that well goodluck
Reactions: ccrs8
I can confirm the issue as well.
0. Fresh flash of gROM then reboot.
1. Flash GingerKernel 7. No sdcard. I removed and re-inserted the SD card and it showed up fine.
2. I rebooted and the SD card was fine.
3. I rebooted again and the SD card was not present.
4. I rebooted again and the SD card was not present.
5. I rebooted again and the SD card was not present. Removed and replaced SD and it showed up fine.
6. I rebooted and the SD card was fine.
7. I rebooted and the SD card was fine.
8. I rebooted again and the SD card was not present. Removed and replaced SD and it showed up fine.
Prior to this kernel I had no SD card issues of this nature. After this kernel revision its been completely random.
Scrosler, just curious....... was that confirmed with your darktremor version or regular?
I'm looking into this issue right now, but so far I haven't been able to replicate it. More details soon.
UPDATE: Just to test, I flashed gROM 2.2 real quick and BAM I get "SD card not present etc" error with ES File Explorer. Removed and re-inserted SD card and everything was golden.
In Your Mom ROM, I have not been able to replicate the issue once.
Based on my preliminary investigation, it seems to be an issue with gROM but I'm going to continue to test things just to be sure.
drew i have actually replicated the sd card issue twice in your mom rom... its not a big deal... all you really have to do is remove the sd card and wait 5 seconds and reinsert it but it has happened to me twice in the last 2 boots... which was from when i installed your kernal last night and then when i rebooted my phone this morning, like i do every morning. but other than that ive rebooted my phone multiple times and only had it happen twice... i intially just thought it was my sd card but now that others have had it happen to them its probably a road bump. OTHER THAN THAT GREAT WORK I LOVE YOUR NEW KERNAL IM NOW ABLE TO OVERCLOCK MORE WITHOUT RANDOM REBOOTS!! :D
i have been using gingerKernel v07 since the release on opti rom ,i havent had these sdard issues:D:D:D:D:D
Thanks for v07, double taps are finally gone and now I can enjoy GB even better.
gROM 2.2 @ 806 MHz SmartassV2
No SD issues here either. Running without a hitch since lastnight. Did a few reboots, no issues.
Should also add I'm on your mom rom
Regular.
Hmmm... does seem to affect Your Moms ROM (I wonder how she feels now, lol). Kinda figured it would considering they are the same base. Also considering this was not an issue on prior versions it would be hard to believe its not kernel related. The other kernels did not act this way.
Maybe its that "CPU bug" between 600MHZ and 729MHZ that never happened on 2.2 rearing its ugly head again ;)
Thats pretty fast!
1. They aren't entirely the same base (well they are, but they're not). In Your Mom, we removed some unnecessary libraries and that seemed to solve a lot of the issues that people have been having. Also, it seems to happen quite frequently on gROM (and OptiROM apparently) but appears to be pretty isolated on Your Mom ROM. Like I said, I'm still researching and investigating this issue. So far, jstntp has been able to replicate the issue once, but it never came up again during his testing.
2. The reason it never happened on 2.2 is because the offending frequencies I stated earlier were entirely unavailable (and in fact commented out in the Xionia kernel source, and the picasticks kernel source doesn't even include them). I built a copy of XioniaRedux that had those frequencies enabled and sure enough, they caused the same screen glitches.
Both matters are still being investigated, I am simply sharing what I have discovered thus far.
Finally, I'd appreciate it if you didn't publicly attempt to insult my intelligence. It is extremely offensive and is not what being a community member is about.
I am running stable at 844! No issues so far. Thanks a million!!
Status
Jackwills2567
