[KERNEL][GB] GingerKernel v08.1 (OC) DOUBLE-TAPPING BUG FIXED!!!
Status
Not open for further replies.
Re: [KERNEL][GB] GingerKernel v07 (OC) SCREEN GLITCHES FIXED!
1. They aren't entirely the same base (well they are, but they're not). In Your Mom, we removed some unnecessary libraries and that seemed to solve a lot of the issues that people have been having. Also, it seems to happen quite frequently on gROM (and OptiROM apparently) but appears to be pretty isolated on Your Mom ROM. Like I said, I'm still researching and investigating this issue. So far, jstntp has been able to replicate the issue once, but it never came up again during his testing.
2. The reason it never happened on 2.2 is because the offending frequencies I stated earlier were entirely unavailable (and in fact commented out in the Xionia kernel source, and the picasticks kernel source doesn't even include them). I built a copy of XioniaRedux that had those frequencies enabled and sure enough, they caused the same screen glitches.
Both matters are still being investigated, I am simply sharing what I have discovered thus far.
Finally, I'd appreciate it if you didn't publicly attempt to insult my intelligence. It is extremely offensive and is not what being a community member is about.
1. So they are the same base.
2. Understood. But the problem was reported on frequencies other than those such as 600 and 748.
3. There was no attempt to insult your intelligence. If you feel that way than accept my apologies.
I am running stable at 844! No issues so far. Thanks a million!!
That's real fast!
For example, I had the issue at 600, 748, and 768. Basically I always had the problem :P
Ok so sdcard had a hiccup tonight. No warning, no messages, phone was running perfect, went to download something but had no room. Sure enough, SD card is gone. Really odd because I have data2ext and that wasn't effected. Reboot took care of it. First time this has happened on any rom/kernel. Your mom rom.
Also to add, never once received a message or error regarding SD rom, was just suddenly unavailable.
I had the exact same problem with sd card not showing and I to have dark tremor a2sd running . Funny thing is it still showed 329 mb of internal mem but no sd card,and most of my apps showed up except for " need for speed".anyway, I rebooted and still no good. It took 3 reboots before it would work.
Also, I'm running mom rom with v7 kernel
A fix for the SD card issue is nearing the completion of testing. This morning I rebuilt GingerKernel in it's entirety starting from the ground up.
So far no SD card issues have been experienced on ANY ROM, no screen glitches have occurred on any available frequency and I've added a new CPU governor, msm7k.
The msm7k governor is based on the "conservative" CPU governor and offers superb battery life, with acceptable performance. For those of you who don't know, the msm7k governor was the stock governor on the HTC Hero.
Yes, its not the "typical" SD card not present bug. This one seems different than the Sprint / LG induced bug. You get no notice at all where as the Sprint / LG bug it gives you notice. Its almost like the SD card is still mounted and function but programs loose access to it. IDK?
Drew says a fix is forthcoming so thats a good thing.
Reactions: dobbs69
Re: [KERNEL][GB] GingerKernel v07.1 (OC) SD CARD ISSUES FIXED!
[NOTE]GingerKernel v07.1 Release:
GingerKernel v07.1 has been released! Main fix in v07.1 is the SD card issues have been (hopefully) resolved. Also, a new governor (msm7k) has been introduced.
The msm7k governor is based on the "conservative" CPU governor and offers superb battery life, with decent performance. It tries to keep the CPU clock as low as possible until it absolutely NEEDS more power. Menus and launchers may seem a bit slow with msm7k but this is expected. I encourage folks to give it a good test and see how they like it! Remember, msm7k is NOT the default governor, you will have to set it manually.
Hit up the first post for the download and changelog.
[/NOTE]
I just flashed v7.1 and am happy to say that my SD card worked perfectly upon bootup. I've rebooted 3 times and each time the SD card worked.
Thanks!
Thanks!
Yep, confirmed bug fixed!
Great job, once again, Drew!
When I flashed this my wallpaper changed, how can I get back the default your mom rom wallpaper, it is not in the list of wallpapers to choose from.
That's weird..... Give me a couple minutes and I will post that background in post #3 of the Your Mom ROM thread so you can download it.
Reactions: nomad85
just flashed 7.1 sd card issue fixed and it seems to boot up alot faster im using gROM it boots up really quick dont know if the kernal has anything to do with the boot up but it boots up fast good job drew
Yes, a good kernel will decrease boot times. Thats actually one of my untold benchmarks. When I evaluate a kernel I look at how fast or slow it boots and that usually tells me how the kernel is going to perform. Just like PC/Windows... If it takes 10 minutes to boot to desktop you can pretty much assume the PC is a dog.
Put thephone on the charger at 11 last night, everything was fine. Woke up at 6 and the SD card unmounted last night again. Running v 7. 1 and your mom alpha. ROM related maybe??
Just flashed this from 6.2 and now my phone is randomly rebooting... any thoughts?
Try clearing cache and dalvik-cache, that can solve issues sometimes. I think you're the only person experiencing this though so without more information there isn't a whole lot I can do.
Has there been any improvement in GPS lock?
Just want to say my phone seems a lot faster with this kernel.another great job drew
Status
Ashok Dharshan
