- Nov 25, 2010
- 15,958
- 2,753
- 0
Is it safe to assume this works on stock rooted EB13 running Ext4?
Yes.
Running EB13 EXT4 with TER 1.5 and Genocide .03a kernel. Getting Quadrant scores well over 1800. Still testing battery, but so far so good.
I would love to do this as well but i thought TER was a DK28 based ROM. How did you make it work?
Sent from my SPH-D700 using Tapatalk
Yes it would be using more power. Pick your poison, undervolt=same as stock perfomance but better battery. Overclock=better performance but uses more battery.
How to remove the stock boot animation on Froyo EB13I flashed back to stock kernel. I still have that android boot over the sprint boot. What's up with that?
Where does that come from?
Source: [KERNEL][GPL]Genocide 1.2GhzOC EB13 Kernel v0.3a (DK28 Compatible) - 2/26/2011 - xda-developers
Creator
Rodderik, Team Viper
Features
1.2GHz overclock
1Ghz 25mV undervolt
EB13 & DK28 Compatible
EXT4 & RFS Compatible
video lag & camera force close fix
Pandora works again!
Change Log
Set defaults speeds to 200MHz min and 1000MHz max (NOW REQUIRES SETCPU TO OVERCLOCK)
Compiled in video lag & camera force close fix by mkasick on xda-developers
Fixed issue with Firmware version in About Phone (FIXES PANDORA)
Set initramfs root UID/GID
Compiled and added cifs.ko to initramfs
*Removed cifs from kernel
Files
Free SetCPU alternative: search "OverclockWidget (Need Root)" in the Market
Instructions
Download kernel zip file, place on your SD card, and flash via Clockwork
Setting speed to 1GHz = undervolt, but no overclock (better battery)
Setting speed to 1.2 GHz = overclock, but no undervolt (more speed)
I personally have mine overclocked at 1.2 and my battery really hasnt suffered much. I was expecting a substantial decline and I havent experienced that in the least. I'm pleasantly suprised.
Where can I get new boot animations? I have dk28 TER 1.5 and genocide kernal.
