[KERNEL][Gingerbread] CM 2.6.35 kernel for Thrive and Phoenix
OK every thing appears to be working fine except I cant seem to log into my Google account keeps telling me I have an incorrect password. I wonder if this could be because I have the extra layer of security through gmail ... cant remember what its called but they sms you a code you are supposed to enter in addition to your password.
EDIT
Yep I'm an idiot that was the problem seems to be working nicely now
Bronz,
this is great. All seems to work pretty good. However, I have no MMS. I added my APN using the RedPocket app from the market, but no MMS.
Thansk for the ROM, it works just fine.
Can you modify any of the roms like that to work on our phones? Or just stock rom
He should be able to do it to any stock ROM, but not MIUI or CM7 they are different enough that we need a custom kernel to run them. As it stands that is the road block we have on running any of the custom gingerbread ROM. We have a mess of kernels that almost work but all of them are missing something like wifi.
You can use that rom with no issue. If you flash arjens ICS kernel, you will not have the blackscreen bug. I am actually using that rom now. The only issue is that you will not have wifi. Im actually using GTR. if you have any issues with the screen flickering or acting up... its because of the overclock. just set min to 320 and max to 600 and that issue will be resolved.
Missing Wifi is a pretty big issue
Hey guys, just thought I'd check in to see how this going, any word from Arjen?
(No rush, I'm rocking a Galaxy SIII now, but I'll never forget my little thrive:D)
Is there a way to fix the black screen whenever you try to unlock the phone on a gingerbread rom on the lp506
Sent from my LG-P500 using Tapatalk 2
I fixed wifi :D
Will upload later along with cm7 for phoenix/thrive.
Had some problems in private live, our son has autism. Won't be around much, but I will try to come along as much as possible.
Sent from my GT-I9300 using Tapatalk 2
hard to hear that, i know not everyone trully uderstand how its to be in that situation, but i guess everyone knows its something to respect because off the extra effort you have to put each day for you and your family o:... even if its only of words, you have my support, from hermosillo, sonora, mexico to wherever are you from (:
Reactions: _Arjen_
I fixed wifi :D
Sorry to hear that, wish the best for you and your son
Sent from my LG-p505 using Android Central Forums
I'm not sure why but flashing this rom, JoyOS 1.1.9 - xda-developers with arjens lgp505icskernel-19062012.zip and wifi and everything is working fine. It's definitely 7.2 based rom. I haven't tried other GB roms. I flashed joban's kernel right after the rom, and it wouldnt boot. so without wiping or anything i just flash arjens kernel. it booted perfect after that. Also no blackscreen bug and can OC. :)
Reactions: renauldo86
liquidsnake757
