[KERNEL] OC kernel for Xoom Honeycomb 3.1
Wifi version so far so good, no reboots on 1.5 ghz. Have you noticed any problems on your wifi xoom since building this kernel?
65.291 linpack
4142 quad
Thanks~
Just so there are no problems I posted a separate link over at XDA so this kernel did not get confused with BRD's
Thanks camblue.
Strange, the kernel and ramdisk should be identical between 3G and WiFi only models, with only the command line being different. I've uploaded another version, if you're feeling brave please try it out.
No major problems thus far, had a browser crash when I tried to see how fast I could scroll down a long page.
I didn't even check last night but I lost 3g too. I think I can go without it for a bit though.
So no joy with the latest version (previous post) too? Ah well, I guess this is why I don't release my kernels into the wild, when I struggle to get mostly stock code properly working :p
I'm sure BRD and his legion of testers should have something out very shortly. Tiamat already has quite a few changes from AOSP, so it should be interesting to see what comes next. Nothing but respect for him and his work of course :)
Since bigrushdog et al haven't yet posted updated kernels for Honeycomb 3.1 and my overclocking itch needed scratching, I thought I'd share my kernel for Xooms running 3.1 for any other impatient souls. This is forked from AOSP, but with some features like micro SD support borrowed from Tiamat :) The kernel is configured differently, but everything you'd expect from Tiamat should be present (well, except for tun.ko) including the 1.504GHz clock speed.
To install, place the appropriate zip file on your micro SD card and use ClockworkMod Recovery's install zip from sdcard option. You can also extract boot.img from the zip file and flash using fastboot from your PC.
WiFi-only
WiFi+3G
I don't use github at present, so the source code lives on my PC. If you want it for any reason, just let me know. Many kudos to bigrushdog, coolbho3k and Koush.
Some benchmark numbers (take with sufficient salt)
Linpack: 63.995 MFLOPS
Nenamark1: 52.1 fps
Quadrant Standard: 4034
Thanks for your reply! Do you mind if I link your post (and attribute the great efforts)here? I will write extensive review of it too! =)
BTW, what is the name of this kernel? (just to avoid any confusion)
I am going to d/l it now and give it a spin. :)
I don't have a name for it, as it was to be a stopgap solution until a more awesome kernel is released :)
The broken 3G bothers me though, and I can't see what's wrong without a log (a dmesg probably).
Put a name on it, and a version number :)
Good work TRD! Flashing now :P
If I had done anything more than quickly hack a kernel that just about worked with 3.1 perhaps ;)
I hear that the release of the new and shiny version of Tiamat is imminent. I've updated the OP with a new version anyway.
c1 still has broken 3G on 3G US/VZW Xoom.
Thought a reboot fixed it but I was wrong.....can anyone else check if changing the Max settings in setcpu works or if it still maxes out at 1054
Awesome work so far! Let me know if you need anymore testers for 3g!
mitiku Berihe
