Kool-Aid--2.1--new leak!!!
I think I found a bug: by mistake, I deleted a contact from the Gmail contacts so by default, it will be deleted on my phone also. I had a call from that person so I went to add the number to the contact (it deleted the phone # but the email and FB sync data remained). I long press the # and select Save to People > Save to existing contact. I select the contact from my list (its still there) and then I get "The application People (process com.android.htccontacts) has stopped unexpectedly. Please try again. FC
Good catch ill see if i can do anthing about that.
hey beezy, hate to be a major PITA, but i was on vaca over the weekend... and there are a bazillion new posts... did you put up any new ROMs based on the official release yet?
I made a big mistake and deleted all my hard work,im in process of getting eveything back how i had it,as soon as i get it all back running the way i had it ill get up.:(:(
awwwwww i'm sorry Beezy!! That sucks hardcore. I'm keeping my eyes peeled.
If you are into overclocking then there will be a update soon to add that option to this rom.I know a lot of people don't care for overclocking but for those that do it will be up after a little more testing.
dang beezy that sucks! hopefully you can recover everything asap.
Yeah thats the one thing that sucks about developing sometimes you just don't go to bed for days,and i pushed my luck and found out i wasn't that lucky:( Note to self and everyone don't fall asleep with cp on your lap,you can delete stuff in your sleep.lol:p
Don't the pri changes after the 2.1 upgrade? I'm still showing as 1.68_003
spj
has anybody tried the updated superuser app from xda?
rotf beezy, i was gonna asked you how much sleep you had gotten before you wiped your work... that sucks.
Hey beezy anybody else having data problems disconnecting ?? If so any idea on a fix at all? Thank you.
I'm having data issues a couple times a day. I'm not sure if there is a fix. I'm tempted to roll back to a leaked version because I never had this problem until using roms based on the official version.
when im at the edge of my WiFi it takes a sec to get back onto mobile and programs will error. i see something popup but i cant see what it is, cause its flashing by too fast. is that the same thing your seeing?
that's an issue with all roms I've tested. even flipz i have to disable network then re-activated it to resolve my issue, i thought it had something to do with sprint network
All i have to do is tap on the browser it will usually open the 2nd time around. If NOT then i run the device self service app and all is well.
so i've been running sugar free for awhile now and noticed something is buggy. my sense freezes up often and random processes force close.
I'm willing to try the other two options, but i don't want to deal with the sluggish anymore. Is anyone else having this problem?
hmmm... so i decided to flash kool aid high, and the expresso theme... and now my phone is stuck between the HTC brilliant screen and the Sprint Now screen... back and forth... i wiped everything before the flash... do i need to wipe something again? Are these two not compatible? I haven't flashed any other mods yet. just those two.
xXxMegaVegaxXx
