Kool-Aid--2.1--new leak!!!
hey beezy420, I read your post from friday. r you releasing a new rom?
I had to start back over:( Im working on it again,there will be a little add-on up shortly for anyone that has had the audio-loss issue to try.
In trying to find out exactly what all that logcat data means, I found that you can also type lolcat for the same result - lol.
one more question beezy, do you recommend using the clearlock from option 4 on the Kool-Aid sugar free rom?
Im not sure if it will work properly with this rom.I think a few pages back someone said what they had tried.If you want nadroid then give it a try.Thats a pretty easy one to fix if it doesn't.
Bump,everyone there is a little add-on front page its a kernel i compiled from toast source,Its not set up to be OC.This might fix the audio loss problem that some have give it a try let me know.
I try all of them, I notice a couple of things happening to the phone. I wasnt sure if it was the rom or the mods. thats why I wanted your opinion.
I try all of them, I notice a couple of things happening to the phone. I wasnt sure if it was the rom or the mods. thats why I wanted to ask you.
If you could please tell which do/don't work then i can see what has to be done to make them work.That would be very helpful and much appreciated.
yep so im just movin this here. seems ive encountered a bit of a bug, the lower buttons/track ball light do not seem to work. maybe when it was flashing something was skipped or corrupt but none the less has anyone else seem to be encountering this? im running KA high...
i hear that everyone is having audio problems.Exactly how do you know when you loosing audio? when on the phone or listening to music?
Hey thanks.Everything should be working trackball,lights,light sensor.Are the lights behind the bottom buttons working?
If you lose audio after getting off a phone call.Things are screwy in the kernel for some people things aren't resetting the way they are suppose to.If you flash the add-on it won't hurt nothing even if you haven't had audio problems.
I flashed clearlock, expresso, clearexpresso and 3d Gallery on the KA sugar Free. I kept Clearexpresso with 3d Gallery. I noticed the following problems: every time I made a call the dial pad was very slow. Once I hit the call bottom, it took 5-10 seconds to get the connection screen(android figure). Then I decided to wipe and flash again KA sugar free with the clearlock and noticed a small delay on the dial pad and call screen. It only happen with the first call, the second and third call worked properly. I am about to flash again and keep KA sugar free with no mods to try for a while.
Cool,ill try and get a clearlock up later,have to go out to eat with the old lady:( I guess i have to spend time with her and not my phone for little while,but gotta love her for putting up with me always do something with phone.:D
I think I found a bug: by mistake, I deleted a contact from the Gmail contacts so by default, it will be deleted on my phone also. I had a call from that person so I went to add the number to the contact (it deleted the phone # but the email and FB sync data remained). I long press the # and select Save to People > Save to existing contact. I select the contact from my list (its still there) and then I get "The application People (process com.android.htccontacts) has stopped unexpectedly. Please try again. FC
kitlis
