Koush's 2.1 Rom
  • Thread starter Thread starter Roy Aguilera
  • Start date Start date
when downloading the rom from rom manager app, it has a pop up to select "google add ons" and "modules" do i select both or 1 or none? this is diff then when i use droid root pro
I always choose both! Idk if it makes a difference if you choose both but it brings gmail, gtalk, goggles, and any other google product. So I always choose both just incase.
I think that the add ons probably mean google goggles, news and weather, and amazon MP3. I'm not sure though, so please correct me if possible.
You should meet my friend Cory Streater. :D
Is he inclined or declined? ;)
I'm having no problems with 3g or Pandora. I'm younger then Jay Z but older then DA and only a little challenged :)
Well at least your not 100% technology challenged. My girl's mom can't even operate a remote, and she's only 42 I believe (Yes not 30, but still).
Ok i'm not sure what happened here. I was having trouble upgrading from .2 using ROM manager. So i manually saved the zip file on the sdcard and installed that way. But somehow, i lost my Gold Android recovery screen and now i get the Clockwork Mod recovery when i power on and hold X. Does this mean i lost all my previous backups i did with sprecovery?
Check the nandroid folder in the sd. Before using the rom manager, it told you that you were gonna flash a new recovery. That is how you lost it. You can always reflash your old recovery with droid root pro.
Not what you want, trust me lol
Thank god she looks like her aunt more =p
Lol.
So da how is 5.0.5 is it a big update or just small bug fix haven't gotten around to flashing it yet
Cool ill probably switching tons when these bugs start to loss me off like today just for a good daily Rom
Will clockwork orange recovery block the ota like sprecovery dose. I'm sure it a yes but with 2.1 suppostly coming wanted to make sure.
just stepping in to the new update, tried to update with rom manager and had it come up not working; got to the rom install screen in recovery and got aborted (bad) was the reasoning... i guess ill just try again, or download via cyanogenmod form and install off sd card that way
tried again and no luck, on the forum it has 5.0.5 and via rom manager i get 5.0.5.3 ill just load the 5.0.5 from the forum
I'm back in koush land after almost three days playing with sense needed to switch I miss sense already
what were the bugs like in sense land? live-able or pretty bad? i haven't wanted to switch roms and i'm not too tempted by sense really. but i'll give anything a go! ^_^
on the 5.0.5.3 there is listed on the bottom of Koush's post the
Google Addon: EPE54B
From what i can find this is a radio update, right? Anyone try it, any luck or improvements?
With swap enabled x1 is very good other not being able to receive calls using 3g and having to reboot after turning off wifi it's great. Now x1b is a different story just took a step back in stability
SBASF
