Koush's 2.1 Rom
  • Thread starter Thread starter Roy Aguilera
  • Start date Start date
I have both don't know how. But I just got the notification of the .1 update downloading now
Aside from the features mentioned that were implemented, are there any performance improvements or the same as. 5
Hey I'm switching over to try out 5.0.6.1 from another ROM where I was using the Nextheme (which I loved).... I used Cyanogen's 5.0.5.6 and used the Smoked Glass Esque Theme then (which I also love lol)
Now to my questions ..... other than the fact that the battery icon is a little different I have no idea what the difference is between the Nextheme and Smoked Glass Esque Theme that are available through ROM Manager, the updated versions aren't out so I have a day or two till I load one on so if anyone could let me know if there is a difference, and what it is that would be great... I did skim through the threads for them at cyanogens forums but nothing stuck out.... Thanks guys!
For Reference...
Smoked Glass Esque Theme Thread
[Theme] Smoked Glass-Esque V1.4.1 - Updated 4/13/10 - CyanogenMod Forum
Nextheme Thread
Nextheme V2.0 - Cm Droid V5.0.5.3 (3/25/10) - CyanogenMod Forum
After I upgraded to 5.0.6.1, I can't download any of the overclocking kernels in ROM manger. They're there, but grayed out. Anyone else get this problem? And where can I go to get the P3Droid kernels to get em manually if there is no fix for this.
I have been loving but out of no where this morning it went into a endless reboot sequence. I restored an old version and all is well again. This was running great for 2 or 3 days then bam couldn't get it to work.
Does any body have any recommendations for themes for this. At the current time I'm waiting till JRummy's version is put out on rom manager but if there is a goodvtheme that is worth using then ill update and then theme. Screen shots or links to threads with screen shots would be appreciated. Thanks all
Not sure if its on the ROM Manger but JRummy did put some mirror link sites up. Just downloaded it and installing now.
Anyone having gmail issue? Since I upgraded to 5.0.6 the other day and then to 6.1 I can not send out an email however I'm able to receive them. Not sure if this is a gmail issue or maybe upgrading screwed something up and I need to wipe.
I installed jrumy rom Butts for some reason the bottom of my setcpu widget is cut off. Anybody else having the same issue?
.5 is the last stable version of cyanogen's/koush's rom. .6.1 is the newest stable version.
i havent noticed too much of a difference
HuanNguyen
