Koush's 2.1 Rom
  • Thread starter Thread starter Roy Aguilera
  • Start date Start date
i got it to work. i had to revert back to stock cyanogen rom and then install the new one. it is pretty sick, im not gonna lie. i like the way it looks and the wallpapers that come with it compliment the rom a lot. i like it.
one question though,, how do i remove the htc mod keyboard. i want to replace it with the custom one i made a few days ago but when i try to install it , it wont let me. so if i can figure out how to uninstall the one that comes with the rom i can probably install a diff one. any ideas?
good idea, i never tried it before but i always hear people saying how it is a great app. ill give it a shot.
thanks DA for the heads up on this rom. def makes waiting for the zeus droid rom easier.
hows the incredible treating you
Great, but I still play with my Droid. Droid is one of the best phones I ever owned.
Would I be able to download the zip, transfer to root of SD, then use ROM Manager to install?
Hmm tried ROM manager and can't get it to work. I'll just try a manual flash then.
If your currently using a themed cyanogen rom your going to have to instal the stock cyanogen rom first and then instal the drotheme. That's what I had to do because I couldn't wipe jrummys rom without doing that.
And the link to get the drotheme is in this thread. Its on the previous page or it might be before that. DA (Roy) posted it.
I really like this theme a lot so far.
Funny how even when my Droid is my secondary phone, I am still ahead of the game. :p
Well DA that's why we need you to stay active here. What would we do without you haha.
Out of curiosity if the Zeus Droid Rom gets a flawless release. What are you going to do?
Could someone post a direct link to the download? I am having more trouble than I should finding it.
Ok so I have this running and installed the 1000 mghz bekit low voltage kernel but my Droid's battery and CPU got really hot. My settings were at 550-800 mghz and my battery got up 42 degrees celcius and my CPU at one point was at 52 degrees. What kernel is everybody running that is using this?
I will keep both.
P3s Kernel.
what would you say is your average temps when using it normally and which p3s one are you using?
my cpu jumped that high only when i played a game for like 5-8 minutes. it was at 550-800. i am just trying to figure out if it is the rom or the kernal. i just don't get how quickly it jumped that high. i thought i was gonna fry my cpu haha. right now i have the bekit 800 low volatage 5 slot kernal but if your temps are better than what mine are at currently then im gonna make the jump.
What game were you playing and don't forget playing a game is taxing on the CPU so the temp will spike but it should level off I wolf say try p3's kernel those are the ones I run with this Rom and it has never run hot
It's called super ko boxing 2. I'll try p3 kernel now. I'll let you know how it goes.
Hey does anybody know how to pull the wallpaper from a Rom using root explorer? Later today I'm going back to jrummy'srom because the temp keeps going really high without much use while using drotheme. I like the wallpapers on the theme though so,I just want to pull them so that I can place them on my,SD card.
Hmladlossau
